SolaraGuy.com • View topic - anyone heard of these luminics hyper white bulbs???
Postby geminiz » Mon Sep 05, 2005 6:37 pm
http://www.automotivelightingusa.com/in ... ts_id=1020
This site has the low beam (H11) and hi beam (9005).
Does anyone have any reviews on these bulbs?
I spoke to customer service about them and he said these bulbs are brighter than the stock bulbs and are brighter than the Nokya because it is not as blue.
Did anyone change there front yellow turn signal lights?
Is that something that can be easily installed as the headlights?
geminiz
Postby DatSRBoi » Mon Sep 05, 2005 8:38 pm
Welcome to solaraguy... I dont think anyone here has used those before.. Good luck
Re: anyone heard of these luminics hyper white bulbs???
Postby cklinh » Mon Sep 05, 2005 9:48 pm
geminiz wrote:Did anyone change there front yellow turn signal lights?
I have, it's not that hard... search in the forums, one of the members (TS04, maybe?) has a tutorial on how to change the turn signal lights.
cklinh
Postby kgzero1 » Tue Sep 06, 2005 8:16 am
I have heard of them. They were all the rage on the scionlife.com forums when I used to have an xA. Most people tend to rave about them. I have never tried them for two reasons:
1) I am not a big fan of hyper white, as they tend to be bluish and
2) These luminics bulbs were not street legal when I last checked. Don't know if this is still the case.
And they are not brighter than stock, nothing is brighter than stock except HIDs of course.
I say that if you get them, buy them off their website, other wise check out http://www.scionlife.com/forums and search luminics (the search bar is really small on the top left), you will find a crap load of info on them.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
thanks for the replies
Postby geminiz » Tue Sep 06, 2005 9:24 am
After reading reviews from scion life, the people there are having problems with the harness melting. Is it because there low beam wattage is suppose to be 51 watts in which the bulbs are made to be 55 watts?
I don't think I'm going to take a chance since on one here has used them.
What do you guys recommend for aftermarket halogen bulbs?
I want something really bright and just a little bit of blue tint.
I don't want to lose any more lighting than the stock bulbs.
geminiz
Postby cklinh » Tue Sep 06, 2005 9:58 am
Check this thread for wattage issues from DocJohn
http://www.solaraguy.org/viewtopic.php?t=11064
more specifically,
http://www.angelfire.com/ky3/gabby/bulb_test.htm
which has information regarding the theoretical max wattage the harness can handle.
Now, for pics of the bulbs he did the tests on (Nokya Arctic White Stage II, sorry, I hadn't taken any pics before I removed mine, these are DocJohn's)
http://www.angelfire.com/ky3/gabby/lights.htm
cklinh
Nice research
Postby geminiz » Tue Sep 06, 2005 7:36 pm
Thanks for finding me the benchmarks by John.
Since the wattage for low beam is 55 watts, the Nokya is 80 watts... with the benchmarks by John stating that the harness should be able to handle the wattage.... shouldn't the Luminics bulbs be fine since they are only 55 watts?
geminiz
Postby kgzero1 » Wed Sep 07, 2005 7:30 am
Good point. They should be okay, I guess.
I am actually condsidering getting some xenomatch plus (these are actually white, not bluish) bulbs from hoen. I was thinking of using the H11's they have under foglights since those run at 55W. I would also get the H10's under foglights.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
confused?
Postby geminiz » Wed Sep 07, 2005 9:52 am
I thought the Xenonmatch Plus bulbs are 80 watts.
Why are the Luminics hyper white bulbs street illegal?
kgzero1, where did you get the front console part for your aftermarket stereo system?
Was the factory stereo easy to take out? Can you please tell me how you got the whole factory stereo out?
geminiz
Postby kgzero1 » Wed Sep 07, 2005 12:19 pm
The xenomatch plus do run at 80 watts, but I looked under fog lights and those xenomatch plus bulbs run at lower wattages. I just don't know if I should just go for the higher ones. I just don't really want to change the harness.
They Luminics bulbs are not Dot approved, therefore, illegal.
If you mean the dash kit, I got here: http://store.yahoo.com/mobile-emotions/20tosodainki.html
I got free install with the head unit I got so I let them do it, but I installed the xm receiver and adapter myself.
I should have the instructions for this at home in a pdf file. I will pm you with it later tonight.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
Postby Arthur2k4 » Wed Sep 07, 2005 5:03 pm
umm...interesting..i might want to get the blue ones or hyper white for my fogs which are silverstar right now..the silver star is nice and bright but yellowish
Arthur2k4
Postby kgzero1 » Wed Sep 07, 2005 6:38 pm
Siverstars yellowish? I don't know about that. Did you buy it used from ebay or something?
geminiz, pm me with your email, I can't send the pdf through this site.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
Postby Arthur2k4 » Wed Sep 07, 2005 10:50 pm
kgzero1 wrote:Siverstars yellowish? I don't know about that. Did you buy it used from ebay or something?
nope..got it from pep boys...well its not very yellowish but compared to my nokya low beams they are...
heres a pic
there more at http://arthur2k4.250free.com/SolaraBlue/NightPics.htm
Arthur2k4
Postby kgzero1 » Fri Sep 09, 2005 11:16 am
Quick question, for those connectors sold by Hoen, how exactly do you install them?
Would I have to cut the wires going to the headlights, and then solder on the connector or is it just plug and play?
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
Postby Arthur2k4 » Mon Sep 26, 2005 11:31 pm
well i ended up ordering the pure blues for my fogs and hyper white for my friends altima today
Arthur2k4
