SolaraGuy.com • View topic - New Tires
New Tires
New Tires
Postby rohand » Tue Oct 18, 2005 2:21 pm
So, the Toyos that came with my Solara, kinda suck. I'm thinking of getting new tires. My friend recommended the Kumho ECSTA ASX. The only question I have is, is it possible to install 235/50 on stock rims?
Thanks,
Rohan
rohand
Postby GenerationOne » Tue Oct 18, 2005 2:38 pm
before you get burned here, I would advise searching for "tire size" or any substitutable search keywords-just a friendly reminder for the future always search through the archives before posting, some people have little tolerance. Good luck.
GenerationOne
Postby Lone Solara » Tue Oct 18, 2005 2:44 pm
Toyo ? The original tires are Bridgestones. Did you buy your car used ?
Lunar Mist Metallic
Dark Stone Interior
Black Top
K&N air filter
Lone Solara
Postby theprodigy79 » Tue Oct 18, 2005 3:52 pm
Hey Lone, it depends on where you get the car... I've known other people who got their rides with Toyos.
Rohand, check out the link below... I put it together a while ago, I'll add 17"s later, but for now it should help you to figure out what to do... otherwise look up "tire size calculator" on Google and play with the Miata calculator for a while...
http://www.solaraguy.org/viewtopic.php?t=19601
Considering the stock 2k4 came with 215/55R17s (118.25mm side wall), the 235/50s (117.5mm side wall) should be fine, with a total (overall) diameter loss of only 1.5mm...
Peace,
James
theprodigy79
Postby zoomzoomthis05 » Tue Oct 18, 2005 6:01 pm
Lone Solara wrote:Toyo ? The original tires are Bridgestones. Did you buy your car used ?
mine came with TOYO Proxes and it was brand new..had 2 miles on it...
Silver 2005 Sport V6
Updating! =)
zoomzoomthis05
one hot solarachic
one hot solarachic
Postby Lone Solara » Tue Oct 18, 2005 7:33 pm
Ahh, thanks for setting me straight. I actually didn't know that.
Lunar Mist Metallic
Dark Stone Interior
Black Top
K&N air filter
Lone Solara
Postby gone » Wed Oct 19, 2005 6:53 am
Toyo? wow, my stock tires suck! In the rain i feel like im slipping & on long wide turns i have to go reallly slow..cheapies
gone
Postby rohand » Wed Oct 19, 2005 2:16 pm
My Toyos aren't that great. 15k miles and my car's starting to slide every once in a while. They're cheap Toyos.
Thanks a lot Prodigy79. I appreciate it. Hopefully I'll get my tires by next week.
rohand
