SolaraGuy.com • View topic - ECU Diagram
ECU Diagram
ECU Diagram
Postby cRaCkeD oUt » Sat Nov 19, 2005 9:03 pm
Does anyone have the ECU wiring harness diagram? I m going to install a SAFC2 and just wanna hook it up right.
Own yaH! @_@
2005 Toyota Solara SE Sport 5Spd. I4- Artic White
cRaCkeD oUt
Re: ECU Diagram
Postby Nutty101 » Sat Nov 19, 2005 11:49 pm
cRaCkeD oUt wrote:Does anyone have the ECU wiring harness diagram? I m going to install a SAFC2 and just wanna hook it up right.
Humm. I have everything for a gen1 1/5 but no gen 2. Sorry..
Nutty101
Postby Down2TheC » Mon Nov 21, 2005 11:22 am
What feeds do you need? I'm guessing it's similar to the cp-e "customizer" feeds. If you send me a list of requirements I can tell you which wires.
CP-e takes ignition coil #1, MAF signal, power, ground, and TPS.
Down2TheC
