SolaraGuy.com • View topic - Need help installing Remote Start
Postby someazn » Mon Nov 28, 2005 7:37 pm
Anyone here good with installing remote starts (clifford rsx 3.5)? Stupid longo toyota won't help me install it. (Sorry, our technicians are not good with remote starts at this moment.) 626 area, hit me up and we'll work something out. Thanks.
someazn
Postby boaclub923 » Tue Nov 29, 2005 3:53 am
do u konw DivisionR?
call this guy, Nelson,
i think he can help u out...
626-625-3060
u can tell him u were refered by a guy call Brandon who drive 04 solara...
he should understand.
boaclub923
Postby juicedsolara » Tue Nov 29, 2005 5:53 am
they aren't really all that hard, you will have to find at your harness under the column: 12 volt constant, ignition, possibly 2nd ignition, starter, accessory. You will need to find your parking light wire, lock, unlock wire, and your tach wire. But that's really all the wires you will need to find in the car.
juicedsolara
Postby Aotoyota » Fri Dec 02, 2005 1:53 pm
the wires listed above along with a transponder module.
Aotoyota
Postby Biggi_e » Tue Dec 06, 2005 2:42 pm
what other kinds of keyless remote start systems are there?
Postby rohand » Wed Dec 07, 2005 12:06 pm
There's the Hornet 564T two way alarm system. That's what I'm getting in about a week or so. I actually had a question about that. Since our cars need the chip in the key to start, is there any way to bypass it?
Thanks
rohand
Postby Biggi_e » Wed Dec 07, 2005 2:29 pm
question for someazn, i was reading the specs on the clifford rsx 3.5 and thats one of the best ive seen online for now, i was wondering what prices have you got and where? if you could let me know i would appreciate it. Thanks
Postby Dawgz » Wed Dec 07, 2005 2:54 pm
i have a 3.5 too, they use a bypass module that has a spare key that has the chip in it but the actual Metal part of the key with the grooves to unlcok the doors or to put it in the ignition was cut, so its just the transponder in it, this doesnt disable that security feature of the transponder so thats coo...a shop did all this for me...
