SolaraGuy.com • View topic - clear corners
clear corners
clear corners
Postby KSolara » Mon Dec 12, 2005 3:37 pm
I want to clear my corners and i was wondering if i need to replace the yellow diffuser with another one or just take out the one that is on.
o4 SE I4 Lunar mist
KSolara
Postby Jack Soulfire » Mon Dec 12, 2005 6:52 pm
Try searching first.
http://www.solaraguy.org/viewtopic.php?t=11287
Good luck.
2006 V6 Solara SE Sport
Jack Soulfire
Postby KSolara » Mon Dec 12, 2005 7:29 pm
i read mikes tutorial but my but i kno some cars need to replace the reflectors with new ones when clearing the corners.. i was just trying to make sure that i didn't need anything like that
o4 SE I4 Lunar mist
KSolara
Postby michaels artic frost » Mon Dec 12, 2005 7:57 pm
Several of the members from the forum has clear cornered their headlights using the tutorial and took the necessary precautions and they have not had any problems.
GL if you do decide to go thru with it and definitely post pics.
It's been over a year since having the clear corners back in Sept. of 2004 and they're still no problem as of yet. I had some condensations issues in the beginning, but that was because I didn't seal it well enough. I went back later and resealed it and it's fine since.
-Michael
Updated 06/01/12: Michael T's
Postby Biggi_e » Tue Dec 13, 2005 9:35 am
i had done clear corners on my car from michaels tutorials bout it. Pretty much i took off the bumper, took the headlights off, unplugged everything, got a head gun and went around the corner of the headlights near the refelectors, waited till it heated up nice to open up and got like tiny plier or tongs or wutever u have you can use and pulled them out. Then use clear weather sealent and clamp it down with rubber clampers(i used my hands also) and then plug the wires back up and put everything back on. Estimate time is took me was about 3 1/2 hrs to 4 hrs. Very very time consuming but im am glad with the outcome
