SolaraGuy.com • View topic - HID vs. stock
HID vs. stock
HID vs. stock
Postby dannyssolara » Sat Dec 24, 2005 9:07 am
Yes, I know... a lot of people here are going to rag me about this but here is my honest opinion. As far as usable light do not get HIDs, UNLESS you do a full retrofit using a genuine HID lens. I have the HID kit (not a retrofit) and the look great from outside, but from behind the wheel the stock produced more "usable" light in projecting light down the road in front of me. I, like many of you, do not like the stock color but I am not sure if any of you have tried using an H9 bulb (which is a 65 watt high beam bulb) in the H11's place. The projector lens will keep it from acting as a high beam in the way of the cutoff focus of the low beam's lens. The H9's socket can be modified very easily to fit into the H11 socket. I am going to do this myself and will post pics when I am done. Again, I know that the HIDs look better aesthetically, but functionally the light in front of the car does not project farther or appear brighter, just the side of the car does.
dannyssolara
Postby linmk2 » Sat Dec 24, 2005 9:55 am
What is the "temp" of your HID set up?
Howard
linmk2
Postby dannyssolara » Sat Dec 24, 2005 5:08 pm
McCullough 5300K kit
Here is a good site for lighting: http://www.danielsternlighting.com/
dannyssolara
Postby DatSRBoi » Sat Dec 24, 2005 5:34 pm
Mines... "Okay"
Postby Biggi_e » Sat Dec 24, 2005 8:09 pm
i have jdm 8000k on my gen2 and i love them
Postby someazn » Sat Dec 24, 2005 9:37 pm
try reaiming your headlights, i did so and its hella better now. more useable light =) you wont get squat from hid if you dont reaim your headlights
someazn
Postby NeFaRiOuS_SLE » Sat Dec 24, 2005 10:30 pm
Yeah... Although I don't have true HID now (but I will ASAP), I just got a set of Luminics since I didn't get much performance out of SilverStars (plus I don't hear too much good things about them AND a set of "HID-look" lights doesn't look so different from my stock fogs), the range seemed lower. Seeing a connection of how they both seem to perform bad, I realigned my headlights and now it's 200% better. Just my $0.02.
*EDIT* Thanks for bringing up a dead thread from 3 years ago :roll: ! I have a set of 4100k HIDs now 8) .
Last edited by NeFaRiOuS_SLE on Sun May 11, 2008 2:06 pm, edited 2 times in total.
Re: HID vs. stock
Postby MikeATL » Wed Dec 28, 2005 9:19 am
dannyssolara wrote:Yes, I know... a lot of people here are going to rag me about this but here is my honest opinion. As far as usable light do not get HIDs, UNLESS you do a full retrofit using a genuine HID lens. I have the HID kit (not a retrofit) and the look great from outside, but from behind the wheel the stock produced more "usable" light in projecting light down the road in front of me.
I totally agree with you.
I have been doing a ton of research on this. A great resorce is the HIDPlanet forums. What i have come up with is something similar to the problems Acura MDXs have with aftermarket HIDs. Lots of light around the car (aiming at the sidewalk) but no bright focused light in front of the car.
The fix that MDX owners swear by is modifying the housing to allow the bulb (also an H11) to sit 2mm deeper inside. I think this is the same problem we have, and I hope to do a mod sometime this weekend.
I will post results as soon as i can.
MikeATL
Postby XEusioN » Wed Dec 28, 2005 9:34 am
I was thinking about getting a kit, but I might just spring for a retrofit, you can get S2K projectors for under $200, and I'm sure they wouldn't be terribly difficult to mount considering we already have shrouds and projector mounts in place...no worrying about cutting reflectors or anything.
2005 Toyota Tundra SR5 V8
2004 Toyota Solara SE
7.1L - 12 Cylinders :: 442hp/488lb-ft
XEusioN
Postby gone » Wed Dec 28, 2005 9:45 am
I got 10,000k and they look sick
gone
Postby MikeATL » Wed Dec 28, 2005 11:02 am
06toyo chick wrote:I got 10,000k and they look sick
Don't get me wrong, I love the look of my HIDs. It just sucks when i speed over speedbumps in dark parking lots for the 18th time.
MikeATL
Postby BradOwens » Wed Dec 28, 2005 12:25 pm
sry i dont wanna be off topic but how hard are HIDs to install? are they plug and play? ive always wondered if they just fit right in
BradOwens
Postby MikeATL » Wed Dec 28, 2005 1:05 pm
BradOwens wrote:sry i dont wanna be off topic but how hard are HIDs to install? are they plug and play? ive always wondered if they just fit right in
plug and play.
MikeATL
Postby LostSoul » Fri May 09, 2008 11:30 pm
I know its an old thread but what do you guys think about the plug n play hid's?
LostSoul
Postby Toy1mzfe » Sat May 10, 2008 1:28 am
Hella back from the dead.
check out the my profile and look at the hid kit i got on my car. cant go wrong with 70 bucks
