SolaraGuy.com • View topic - weapon r intake install
Postby KSolara » Sat Dec 31, 2005 2:00 pm
I was trying to install the Dragon intake from weapon r but i found that it comes with a extra 10mm pipe that is sposed to connect to the PVC port..
the OEM box did not have a 10 mm hose and i dont have a clue where this PVC port is or what it looks like...
o4 SE I4 Lunar mist
KSolara
Postby dominoSLEV6 » Sun Jan 01, 2006 8:03 am
Sorry to say, but I think you may have bought an intake for the gen 1/1.5 Solara.
As far as I know, Weapon R does not have an intake for your car, and often times I see auctions and websites mislabeled for 99-04 rather than 99-03.
I could be wrong as I don't know a whole lot about Gen 2's, but I believe that's the case. Hopefully you can return it. If so I recommend investing in a Custom Performance Engineering intake. Check cp-e.com for more details.
-chris
dominoSLEV6
Re: weapon r intake install
Postby PhreakdOut » Mon Jan 02, 2006 7:01 pm
KSolara wrote:I was trying to install the Dragon intake from weapon r but i found that it comes with a extra 10mm pipe that is sposed to connect to the PVC port..
I suspect Weapon R copiedthe Injen intake. There is one extra 5/8" tube that should be capped off. See my tutorial on installing the Injen Intake. It should go in the same way.
http://www.solaraguy.org/viewtopic.php?t=18389
Postby KSolara » Wed Jan 04, 2006 6:30 pm
thx phreaked but my friends and i decided to cap the tube the other day when we looked at my budy's accord intake which was capped too..
the intake is working fine now.. ill post pics some day soon... but it sounds sweet
o4 SE I4 Lunar mist
KSolara
