SolaraGuy.com • View topic - TRD Exhaust Installation
Postby cklinh » Fri Jan 13, 2006 5:59 pm
How the heck did you guys get the two bolts/nuts off of the stock exhaust?
I've tried, for the last hour to get the damn things off... is it welded on or something?
cklinh
Postby PhreakdOut » Fri Jan 13, 2006 7:06 pm
Remove the nuts, but the studs are welded to the OE muffler.
The TRD muffler doesn't come with new bolts, so you'll need to head to the hardware store to get some new ones. Go with stainless steel. You'll be glad when you remove them.
Re: TRD Exhaust Installation
Postby JavaJoe_2 » Fri Jan 13, 2006 7:08 pm
Use a grinder or just cut them and buy some new one's.
Got Boost?? :sweet:
JavaJoe_2
Postby cklinh » Fri Jan 13, 2006 7:11 pm
Oh, the exhaust I got came with nuts and bolts.
Phreakd, I also read one of your posts that said it didn't come with a gasket, should I got pick one of those up?
cklinh
Postby SleeperSolara » Fri Jan 13, 2006 7:21 pm
cklinh wrote:Oh, the exhaust I got came with nuts and bolts.
That would be a good idea.
Use some PBlaster and it will make takin' the bolts off better.
Postby WTF?? » Fri Jan 13, 2006 7:45 pm
damm cklinh... youve done quite a bit of mods since we've last seen you at a meet...
i think youve been the only Gen 2 to come around... other Gen 2's are too chicken :lol:
Retired... its been fun Image
WTF??
Postby PhreakdOut » Fri Jan 13, 2006 11:17 pm
Correct: No gasket included.
I reused mine along with some RTV copper sealant. No leaks at all.
Postby Yanks0114 » Sat Jan 14, 2006 12:38 pm
Yup - or you can try WD-40, liquid wrench, or any similar product
Spray on and let it sit for a little bit
Postby cklinh » Sun Jan 15, 2006 10:35 am
Yanks0114 wrote:Yup - or you can try WD-40, liquid wrench, or any similar product
Dang... I swore I sprayed almost half a can of the PB Blaster stuff (on ONE nut) and it still won't budge... I think I stripped one of the nuts in the process... I was SO happy when the wrench moved, only to be let down when I found out the wrench would almost rotate freely now :x
I guess I'll have to go borrow some power tools...
(on the brighter side, that PB Blaster stuff did WONDERS for my outdoor mailbox lock!)
WTF?? wrote:damm cklinh... youve done quite a bit of mods since we've last seen you at a meet...
Hey, thanks for noticing! I'm just sorry I haven't been able to make it to more meets (work and planning for a wedding... well, mostly work :)
cklinh
Postby Somedude » Sun Jan 15, 2006 9:09 pm
would a muffler shop like midas or meineke install a TRD muffler?
Somedude
Postby Down2TheC » Sun Jan 15, 2006 11:33 pm
Maybe but I'm sure they'd remove yours for $10. Then drive home loud and install the new one. (Can you say P-grinder?)
Down2TheC
Postby PhreakdOut » Mon Jan 16, 2006 5:26 am
down2thec wrote:Maybe but I'm sure they'd remove yours for $10. Then drive home loud and install the new one. (Can you say P-grinder?)
I don't want to be insulting when I say this ...
I'm confused. This took me about 8 minutes to change mufflers. (6 of which was jacking up the car.) This is the easiest mod on the car. So something is going wrong for you. With this being an SLE, you may not need to jack up the car. (If you're not lowered already.) The SE Sports definately need to be jacked up. The body kit gets in the way of crawling under.
When removing the nuts, use a breaker bar, not a ratchet. (A breakerbar is a ratchet that does not rotate.) This will save your ratchet from undue stress. If it still won't budge, use an extension on the handle. (A cheater bar). Basicly, this is a piece of tube that can slide over the end of the cheater bar and make the handle longer. The longer the bar, the more leverage you will have to break the nuts loose. They are tough, so don't give up. You'll hear a huge creak when they are coming loose. Hit it again with the penetrating spray and go at it.
Once the nuts are off, you'll have the muffler changed in a couple minutes.
Postby FLUXEMAG » Tue Jan 17, 2006 8:17 am
Just to clarify, you should only have to remove two nuts, right? The other six don't need to be removed, as the muffler's hooks slide out of the rubber gromets.
FLUXEMAG
Postby Biggi_e » Wed Jan 18, 2006 9:34 am
i just got my trd muffler in from richd today, pretty quick shipping! cant wait to install it and hopefully i wont have any problems removing the nuts off
Postby mattyboyl » Wed Aug 02, 2006 1:39 pm
I'll be installing my muffler soon. What size bolts should I ask for and how many will I need. I would like to be prepared. I will also pick up some Copper sealant too. Thanks for the info.
mattyboyl
