SolaraGuy.com • View topic - alternator upgrade?
alternator upgrade?
alternator upgrade?
Postby Dishon » Thu Jan 26, 2006 5:51 am
im about to install a high output stereo system has anyone upgraded there alternator if so how much did it cost you and what brand are you using?
Dishon
Postby bunthy » Thu Jan 26, 2006 6:56 am
search carparts.com >2001>toyota>highlander>v6>tow package. The alternater is at 110amps, instead of the 80 amps(at least in my avalon). Its made for the 1mzfe so its a direct fit. I think it should be $60 shipped.
bunthy
Postby lilmike2069 » Thu Jan 26, 2006 7:24 am
They make a 130Amp alternator for the highlander for the 1mzfe as well... i would just go ahead and get the extra 20Amps
lilmike2069
Postby Dishon » Thu Jan 26, 2006 7:59 am
actually i have a 2004 solara sle v6
Dishon
Postby wiz2 » Thu Jan 26, 2006 8:18 am
Actually your car may be too new to use carparts.com. You may have to hit up the dealer or maye NAPA if you're lucky. A new 130 amp Highlander alternator for the 1MZFE cost me over $300 at NAPA including core charge. None of the dealerships had one in stock in my area, they had to order it from their warehouse in another state. I'm not sure what the 3MZFE alternator specs are, but the Higlander does have a high output version with at least 130 amps. That should work for you unless your system is extreme.
06 DG G35 Sedan 6 MT
motordybe spacer|stillen tube|MRR GT 1 19x8.5,19x9.5 Toyo T1R's
wiz2
Postby Dishon » Sat Jan 28, 2006 5:04 pm
actually that 130 amp alt sounds good to me
Dishon
Postby JavaJoe_2 » Sat Jan 28, 2006 5:33 pm
bunthy wrote:I think it should be $60 shipped.
:drinking: (JK)
Where did you find that price.
$300. is the the average price.
Please correct me if wrong.
Joe
Got Boost?? :sweet:
JavaJoe_2
Postby lilmike2069 » Sat Jan 28, 2006 7:21 pm
ya i think about $250 shipped is the cheapest ive seen for the 130A alternator for the 1mzfe
lilmike2069
Postby Dishon » Sun Jan 29, 2006 8:52 am
:drinking: (JK)
Joe
$60 come on now it does sound too good to be true
Dishon
Postby dishon22 » Sat Aug 26, 2006 8:50 am
ok once the alternator is installed is there any other equipment needed
dishon22
Postby dishon22 » Thu Sep 14, 2006 7:34 am
dishon22 wrote:ok once the alternator is installed is there any other equipment needed
bump
dishon22
Postby DatSRBoi » Thu Sep 14, 2006 8:13 am
bump
No... wait yes... A sub and amp and some new lights and all because you got power to use up for free.
Postby SolaraGuy22 » Thu Sep 14, 2006 8:19 am
What is this equipment going to consist of? If you say w7's, 1000x1, and 300x4 then you're going to need to get a bigger one that 130 :D
Another thing you may want to do is get a ground wire kit or do the big 3.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby Aotoyota » Mon Sep 18, 2006 5:52 pm
will it drop in for us 2az-fe? or are there any suggestions?
Aotoyota
Postby Jon11582 » Mon Sep 18, 2006 6:22 pm
Is the gen2 80A stock too?
You should probably find that out before you "upgrade".
I just did a little googling. This page shows that the Gen2 comes with a 100Amp.
2000 Black Solara SE
Jon11582
