SolaraGuy.com • View topic - Reverse Bulbs
Reverse Bulbs
Reverse Bulbs
Postby dougd4885 » Sat Feb 04, 2006 10:25 pm
i was just wondering if anyone has found brighter reverse bulbs? i had an 03 camry before my 06 solara and i have to say the camry had some bright reverse bulbs, since i got a dark driveway.
thanks.
2006 Solara SE
4 cyl. - 5 spd. auto
Oceanus Pearl w/ Ivory Interior
-Escort 8500 x50 radar detector (blue)
-USA SPEC Dual Aux. Input
-Sirius Starmate Replay ST2
dougd4885
Postby SolaraGuy22 » Sat Feb 04, 2006 10:29 pm
How bright? This bright?
I just bought some hyper white ones at Pep Boys. Check eBay for some. That's the best you'll get without having to retro some headlights.
-Anthony
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby Biggi_e » Sat Feb 04, 2006 10:37 pm
damn those look like headlights =P
Postby sahuddleston » Sat Feb 04, 2006 11:32 pm
try some piaas.... look at www.eautoworks.com they have a great site and a very quick.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby cklinh » Sun Feb 05, 2006 1:49 am
SolaraGuy22 wrote:How bright? This bright?
-Anthony
DAMN! Those are bright! They'd help a lot with the backup camera!
cklinh
Postby Truffles » Tue Jan 01, 2008 12:04 pm
I want to increase the brightness of my back up lights to help my camera display better.
Has anyone had any issues with the ones mentioned in this thread as far as additional heat within the plastic lens?
I have a 2006 SLE Convertible.
Thank you !!!
2006 Solara Convertible
Cosmic Blue
Beige Top
Truffles
Postby NightRider » Fri Jan 04, 2008 10:00 pm
get some piaa bulbs the somewhat blue kind, those are bright.
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby woa_its_j3ff » Fri Jan 04, 2008 11:13 pm
at first in my gen 1, i had white leds, but those suck, strictly only show, even with the wide angled ones.. suck>
im goin back to the halogen bulbs, and may just do what solaraguy22 did with the hyperwhites, as I have the backup camera and it'd help a lot when i reverse out at night.
Postby Truffles » Sat Jan 05, 2008 5:07 pm
One last question on this subject.. is there a trick to removing the bulb socket from the holder?
I pulled out the felt type cutout and found the bulbs.. but couldn't easily figure out how to pull the socket out.. I didn't want to break it trying.
Cosmic Blue
Beige Top
Truffles
Postby [SMAN] » Sat Jan 05, 2008 5:12 pm
Well, to get the bulb out, all you do is twist the socket. And it should then become really loose and pop open. As for getting brighter output there there are 2 options. You could try for a brighter bulb or a "hyper white" (which is usualy dimmer) but i've also seen higher wattage bulbs. Try to find a eurpoean bulb maker that makes higher wattage of the same style that fits in there. The other thing you could do is the 07 tail light swap. With this (combined with the turn signal mod for the LEDS) you can use the blinker section as a backup. This made a HUGE difference compared to my 04 tail lights and it is very bright in the back. Do keep in mind that you will need to purchase new bulbs for that as the ones from the old tail lights are not the same type as the blinker bulb socket. Talk to reggie to get yourself a good deal on the tail lights.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Gadgetjq » Sun Jan 06, 2008 7:11 am
Truffles wrote:is there a trick to removing the bulb socket from the holder?
Check page 320 of your owners manual
Cheers
Gadgetjq
