SolaraGuy.com • View topic - Gen 2 Aftermarket Parts Listing
Postby scLara626 » Mon Feb 20, 2006 8:19 am
ok gen2 has been out close to 3 yrs and i was wondering if we all could jus form a list of all the aftermarkets products that have came out for us? links are most helpful and this will be helpful to alot of us, newbies mostly!
there not to many but i would like to know wut companies hav to offer us....
scLara626
Postby theprodigy79 » Mon Feb 20, 2006 9:46 am
TRD (www.trdusa.com):
Front Strut Tower Brace
Rear Sway Bar
Sports Muffler
Lowering Springs (-1.4" / -1.2")
Air Filter
Chrome Touring Wheels (18"x8")
Alloy Touring Wheels (18"x8")
Painted Alloy Touring Wheels (18"x8")
Convertible windscreen: Part# is PT906-06041
Clutch Assembly (5-speed) PTR15-21051-60
Torque Biasing Differential for 5-speed PTR39-21070
Oil Filter (3.3L) PTR04-00000-15
Oil Filter (2.4L) PTR14-00000-04
N-Type Radiator Cap 18.5 PSI (2.4L) PTR04-00000-03
K&N (www.knfilters.com):
Air Filter, 3.3L & 2.4L (33-2219)
Oil Filter, 3.3L (HP-1002)
Oil Filter, 2.4L (HP-1003)
69 Series Typhoon Intake System, 2.4L (69-8609TTK)
Injen (www.injen.com):
Short Ram Intake, 3.3L (IS2032P or IS2032BLK)
Short Ram Intake, 2.4L (IS2025BLK or IS2025P, also check SP2026)
Custom Performance Engineering, CPe (www.cp-e.com):
Short Ram Intake MAFci Kit, 3.3L
Tein (www.tein.com):
STECH Lowering Springs, 2.4L, should work for 3.3L as well (-2" / -1.9") (SKL68-AUB00)
SS Adjustable Coil Overs, 2.4L or 3.3L (DSL68-KUSS2)
JIC Magic (www.jic-magic.com):
Adjustable Coil Overs (not sure what series or part number)
Eibach (www.eibach.com):
KYB (www.kyb.com)
GR-2
Right Rear Strut 334388
Left Rear Strut 334389
TRENZ (www.trenz.com)
Billet Bumper Grille; Framed Perimeter; Brushed (2737-TFP)
Billet Bumper Grille; Framed Perimeter; Polished (2737-TFPP)
Billet Grille; Framed Perimeter; Full Replacement; Brushed (2305-TFP)
Mike T (http://www.cardomain.com/ride/491339):
Custom Upper and Lower Mesh Grilles (Brushed, Polished, Painted... see site)
Precision Grilles (http://www.american-truck-auto.com):
Billet Grille, Polished Finish, 04-06 (807200)
Bumper Billet Grille (807201)
Mud Guards - select color match:
http://www.trdparts4u.com/Products/parts_list_30.html
Weapon R (www.weapon-r.com):
Secret Weapon Intake System (305-144)
Dragon Intake System (805-144)
Golden Eagle (http://www.goldeneaglemfg.com):
HD Sleeving for 2AZ-FE
Fuel Rail for 2AZ-FE
Brian Crower (http://www.briancrower.com/makes/toyota/2azfe.shtml):
Stage 2 NA application (plug and play) for 2AZ-FE
Stage 2 Booster application for 2AZ-FE
Stage 3 NA (needs springs and retainers) for 2AZ-FE
Valve springs & retainer kit for 2AZ-FE
SS Dished Valves (stock and oversized) for 2AZ-FE
2.7L Stroker kit (106mm stroke up from stock 96mm) for 2AZ-FE
Last edited by theprodigy79 on Tue Aug 12, 2008 12:03 pm, edited 11 times in total.
theprodigy79
Postby Biggi_e » Mon Feb 20, 2006 10:44 am
nice work prodigy
Postby PXLpainter » Mon Feb 20, 2006 3:22 pm
Cool - thanks for taking time to make that list - especially providing part #s :D
Sad thing is tho' - not much out there for our Gen 2s as a whole. :(
Postby MCOjerry » Mon Feb 20, 2006 8:25 pm
What's a gen 3? Didn't think there was anything after 2...
Postby theprodigy79 » Mon Feb 20, 2006 9:20 pm
PXLpainter wrote:Cool - thanks for taking time to make that list - especially providing part #s :D
Sad thing is tho' - not much out there for our Gen 3s as a whole. :(
You're still Gen 2 bro... there's some weird little changes that [may] have occured, however for the most part the parts will still work on your vehicle. The only parts of question are the TRD muffler and the intakes (however the intakes are believed to work but just need verification).
theprodigy79
Postby PXLpainter » Mon Feb 20, 2006 11:07 pm
Yeah, yeah, yeah - slip of the finger there... I obviously meant Gen 2 - not 3. ;)
This is the 3rd year of Gen 2 production and we don't have much for performance or body styling, etc... that's what I'm referring to.
Postby dvdchris45 » Tue Feb 21, 2006 12:18 am
in case you're wondering the part number for the TRD muffler is:
PT901-17400-25
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Down2TheC » Wed Feb 22, 2006 12:47 pm
Sticky this thang and delete the chatter pls... (like this) Then we can keep the list current as stuff comes out. That will prevent a lot of noob posts. "Does anyone make an intake for our car?"
Down2TheC
Postby Biggi_e » Wed Feb 22, 2006 1:57 pm
down2thec wrote:Sticky this thang and delete the chatter pls... (like this) Then we can keep the list current as stuff comes out. That will prevent a lot of noob posts. "Does anyone make an intake for our car?"
haha sounds like me when i first started in this forum
Postby tacti » Wed Feb 22, 2006 2:35 pm
Also, since I4 has the same engine as Gen5 Camry, so I believe that we can use the Ingen intake for Camry I4. (IS2025)
I'll try it (hopefully) by next week...
Tact
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby Down2TheC » Wed Feb 22, 2006 4:02 pm
Or you could buy the filter and put together some PVC for a Home Depot mod... Don't foget the chrome spray paint. :fadein:
Down2TheC
Postby geminiz » Thu Feb 23, 2006 2:03 pm
There is no air intake at all for the 4 cylinder solara?
2006 Solara SE (2.4L w/5 speed automatic)
Lunar Mist
geminiz
Postby theprodigy79 » Thu Feb 23, 2006 2:45 pm
geminiz wrote:There is no air intake at all for the 4 cylinder solara?
I believe, as Tacti mentioned, that the I4 Solara uses the same intakes as the I4 Camry... I don't believe it has it's own intakes though... I'll do a bit of research and post the results.
-James
theprodigy79
Postby tacti » Thu Feb 23, 2006 6:36 pm
Yeah, i'm bidding on ebay for a intake for camry I4.
if i could win the bidding, i will install it next week and post the result.
but i think (and hope) there shouldn't be a problem..
Tact
RX-8 Page
Solara Page
SG Map
tacti
