SolaraGuy.com • View topic - problem with rsb
problem with rsb
problem with rsb
Postby alan8888 » Mon Apr 17, 2006 3:01 pm
I hear some wield noise
after i install the rsb ...when going little bumping round...aroun 35-50 mph
my rsb hit something douno what is it...but it sound wield
alan8888
Postby RichD978 » Mon Apr 17, 2006 3:23 pm
did you grease it enough? what'd you use to grease it? Probably not enough grease in the bushings. Get under and wiggle the bar to see if anything is loose. If not than it just needs more grease in the bushing
RichD978
Postby Down2TheC » Mon Apr 17, 2006 3:50 pm
Also check that the path is clear for it to move when the struts compress. I'll have pics posted tonight for comparison.
Down2TheC
Re: problem with rsb
Postby QuickSEV6 » Mon Apr 17, 2006 4:39 pm
alan8888 wrote:I hear some wield noise
What is a "wield" noise? If it is squeaking sound, then you need more or a better grease in your bushings.
If its a "bumping round" , it's probably something other than the sway bar.
Postby Somedude » Mon Apr 17, 2006 9:15 pm
did you lube the part of the bar where the bushing is suppose to hold? You have to lube it otherwise you will have squeaking noise. Mobil 1 Synthetic grease is recommended as a lube by many members here.
Somedude
Postby WTF?? » Mon Apr 17, 2006 10:27 pm
the "bumping" noise from the rsb hitting something and the "squeaking" noise from not enough lube (:lol:) are totally different... Ive heard both and can identify both fairly easily.
its best if you go to a shop that has the Ramp-Style lift where you can raise the car, but still have the wheels compressed like it was on the ground. From there you willl be able to see what the rsb may be hitting
Retired... its been fun Image
WTF??
Postby alan8888 » Mon Apr 17, 2006 10:44 pm
at last fixed it today...by the dealer that help me to change the engine oil...
don't know how they fix it........ but the dealer people was nice..help me fixed it ,.free of charge
alan8888
Postby mpvpapabear » Tue Apr 18, 2006 10:43 am
Did you ask them what it was? Could help some of us planning on this install soon.
2006 SLE, convertible, lunar mist/blacktop/leather/GFX TRD rsb
mpvpapabear
Postby SleeperSolara » Tue Apr 18, 2006 10:59 am
If it knockin' then you should check the RSB tid rods.
The creakin' is not enough lube.
