SolaraGuy.com • View topic - display button on steering wheel
Postby Biggi_e » Sat Apr 22, 2006 9:40 am
i just installed my eclipse avn5495 in my car so the steering wheel buttons dont work but does that disconnect the display button for viewing the mpg, or how many miles i have left for a tank of gas, etc..?
i need to know quickly b4 i put everything back. Thanks guys
-Eddie
Postby Down2TheC » Sat Apr 22, 2006 11:31 pm
Check in the tutorial section for the steering wheel controls. MichaelT posted the harness/pin that needs to be grounded once you remove the junk from the stock HU. The display button shares a ground with that.
Down2TheC
Postby theprodigy79 » Sun Apr 23, 2006 9:37 am
ground the yellow wire.
theprodigy79
Postby Biggi_e » Sun Apr 23, 2006 8:55 pm
oh ok thanks guys
Postby Yanks0114 » Sun Apr 23, 2006 11:44 pm
theprodigy79 wrote:ground the yellow wire.
I haven't seen mikes thread, but are you sure about that?
The yellow wire may also be the power wire which would be a real bad thing to ground
Postby dvdchris45 » Sun Apr 23, 2006 11:54 pm
Its the right wire...James has done it and so has Kenny (kgzero1).
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Biggi_e » Mon Apr 24, 2006 11:45 am
thank you guys. my mpg is going wild when i drive..dont know why but if grounding that wire is the the answer then it shouldnt be too hard to do. Thanks guys!
Postby kgzero1 » Tue Apr 25, 2006 10:36 am
Yup, yup, it's the yellow wire. Chris, have you grounded yours yet? Or the PAC?
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
http://www.cardomain.com/ride/850364
http://www.cardomain.com/ride/2055035
kgzero1
Postby dvdchris45 » Tue Apr 25, 2006 1:52 pm
kgzero1 wrote:Yup, yup, it's the yellow wire. Chris, have you grounded yours yet? Or the PAC?
LOL dont even get me started on it...I tried both...no luck...I'm gonna write up a thread regarding it sometime soon...
dvdchris45
Postby tacti » Tue Apr 25, 2006 8:02 pm
Isn't that unit double din?
if it's a double din, i think you can connect the steering control wires directly into the head unit.
i'm not sure, but i think i read it somewhere.
can anyone confirm?
btw, it is a great head unit.
Now... RX-8 THE Stock.... :(
RX-8 Page
Solara Page
SG Map
tacti
Postby kgzero1 » Tue Apr 25, 2006 8:21 pm
Wait, it didn't work for you? Damn.
2005 Solara SE
4 banger 5 speed MT
Lunar Mist Metallic
kgzero1
yellow Wire
Postby Kjk747 » Mon May 01, 2006 6:42 pm
Hey Guy's it is the yellow wire. It has grey spots on it right next to the blue and green wires. Ground this wire out anywhere on the metal body houdsing or anything that is attached to it(besides plastic obviously). I also installed my pioneer avic n2 and yes I am the most skeptical person about posts but the bypass does work. after like staying up almost all night deciding wether or no to do it, But for anyone who is like me and still undecided it is true if you jump r197 and ground out parking brake your off withouht limitations.
Kjk747
Postby Biggi_e » Tue May 09, 2006 1:23 pm
i got it to work. thanks for the input guys, now i need to buy that thing for volume control and etc.
