SolaraGuy.com • View topic - HELP!!! pick my combination on lighbulbs
Postby LaraV604 » Mon May 15, 2006 11:56 am
hi, everyone
I am thinking about to replace my high and lowbeans and foglight with NOKYA bulbs; however, i need your opinion on which combination is good or you have a better suggestion, thank you in advance. Here are the chooses:
1) stock highbeam, NOKYA Arctic White lowbeam, stock fog
2) stock highbeam, NOKYA Arctic White lowbeam, NOKYA Hyper White fog
3) stock highbeam, NOKYA Arctic White lowbeam, Nokya Arctic Yellow fog
4) NOKYA Arctic White highbeam, NOKYA Arctic White lowbeam, stock fog
5) NOKYA Arctic White highbeam, NOKYA Arctic White lowbeam, NOKYA Hyper Yellow fog
6) NOKYA Arctic Yellow highbeam, NOKYA Arctic White lowbeam, stock fog
7) NOKYA Arctic Yellow highbeam, NOKYA Arctic White lowbeam, NOKYA Hyper Yellow fog
2004 SE Sport V6 Solara
http://www.cardomain.com/ride/700302
LaraV604
Postby cklinh » Mon May 15, 2006 11:57 am
Why do you want yellow high beam?...
cklinh
Postby LaraV604 » Mon May 15, 2006 12:04 pm
would it look good though for the DRL?
LaraV604
Postby cklinh » Mon May 15, 2006 12:11 pm
That will be hard to say... with the DRL's, a lower wattage is applied across the bulb, causing a dimmer light...
Since noone has tried it with a yellow bulb, noone will quite know what it will look like. (i.e., with a "white" bulb, once you lower the wattage, the light output looks amber)...
So... will it look yellow? will it look stock amber? One way to find out...
But, you'd also lose the effectiveness of the highbeam, no?
cklinh
Postby LaraV604 » Mon May 15, 2006 12:18 pm
Thank you for the opinion.
If I go with my first option, will the wires get damage since i have two stock lightbulbs and one Nokya??
LaraV604
Postby woa_its_j3ff » Mon May 15, 2006 12:20 pm
choice 3.
Postby DocJohn » Wed May 17, 2006 7:58 am
For about the past 1.5 years I've been using NOKYA Arctic White highbeam, NOKYA Arctic White lowbeam, and HOEN "All-weather" (yellow) fogs, which is similar to your choice #5. I like this combo just fine.
<B>2004 Solara SLE V6 with mods (sold 10/10/06)
DocJohn
