SolaraGuy.com • View topic - TRD Rear Sway Bar question *updated 5/23/2006*
Postby Somedude » Tue May 23, 2006 1:46 pm
Would the innermost setting on the TRD RSB make my car's handling too stiff?
I've got it on the middle setting right now, I just want to know if the car's handling will be too stiff for normal driving if I set it on the innermost hole.
please help
thanks :D
Somedude
Postby Phylum » Tue May 23, 2006 2:05 pm
I don't own one but I'd like to think that yes it would make it stiffer. and the very first hole or lower down would make it loose. Don't take MY word for it though!
2005 Silver Solara SE I4 5 Speed MT - All stock for now
Phylum
Postby SleeperSolara » Tue May 23, 2006 2:07 pm
The inner most hoel is the stiffer settin'.
The outer hole is the stock settin'.
Postby Somedude » Tue May 23, 2006 6:04 pm
I test drove the car after I set the bar to the innermost hole, wow is all I can say. On really tight corners, there is hardly any body roll.
Somedude
Postby TW85 » Tue May 23, 2006 7:39 pm
What does the RSB cost installed? If I do not change cars I am thinking of having it installed...
Moved on to better things...
TW85
Postby Somedude » Tue May 23, 2006 8:06 pm
I did the install with the help of my dad. It is pretty easy and when you buy the RSB, it comes with an installation manual.
It will save you money if you installed it yourself.
Somedude
Postby TW85 » Tue May 23, 2006 11:01 pm
I just placed an order for the RSB and TRD filter and realized I used my parents' credit card by mistake. Now I have to cancel that order and reorder using my debit. :x
TW85
Postby PXLpainter » Wed May 24, 2006 12:20 am
I'm hoping to pick up an RSB this weekend... (keeping fingers crossed they have one in stock through my source!) - I'd like to install it on Saturday while my girlfriend is gone for the day so I can have the garage all to myself! ;)
Postby Down2TheC » Fri May 26, 2006 4:53 am
Dude, you're gonna love it! I had no manual in the box and it wasn't rocket science. Pics in the tut section if you want to prep.
1K! whatever...
Down2TheC
Postby kingkakyle » Thu Jun 15, 2006 9:05 pm
about how much did u guys pay for ur RSB?
i was looking around and found some at a little elss than 200 shipped (around 188)
Postby variant » Thu Jun 15, 2006 9:29 pm
150+shipping is the norm
variant
Postby PXLpainter » Fri Jun 16, 2006 9:13 am
Mine was $158 out the door locally.
Inner-most setting and absolutely no noticable difference in ride - only corners like it's on rails now.
Postby KSolara » Sat Jun 17, 2006 12:17 am
where can i order the RSB and
is there a front one too?
o4 SE I4 Lunar mist
KSolara
Postby Somedude » Mon Jun 19, 2006 3:46 pm
KSolara wrote:where can i order the RSB and
there is no Sway bars for the front but we do have the Front Strut Tower Bar.
here's a picture of it:
Somedude
Postby mpvpapabear » Tue Jun 20, 2006 10:05 pm
~$180 from Reg.
Faulty install for $50
I suggest doing it yourself unless you got a dependable place. I regret wasting my $50 but it was a bitch just to redo itmyself cuz I had to put grease on the bushing and I wanted to switch from the middle to the innermost setting.
If you do it yourself, get a safe pry bar to get the rsb into position.
From experience the middle is much better than stock but the innermost is even more better than the middle. Really does track better in the rear but makes you think the front is sloppy.
2006 SLE, convertible, lunar mist/blacktop/leather/GFX TRD rsb
mpvpapabear
