SolaraGuy.com • View topic - spark plugs
spark plugs
spark plugs
Postby Aotoyota » Mon Jun 05, 2006 9:27 pm
Who's changed them and what kind? and does the solara run platinum or iridium? part numbers would be appreciated also!
Cheers
Aotoyota
Postby RDKamikaze » Mon Jun 05, 2006 10:58 pm
I don't know who else has changed them because they don't have to be changed/maintained untill you reach 100k miles, but this info would be appreciated for me too when it comes time to change them.
RDKamikaze
Postby Aotoyota » Tue Jun 06, 2006 11:03 am
100k miles huh? I guess Im on my own on this one then?
Im coming up on 30K and it says in the maintence that spark plugs
are changed.
Aotoyota
Postby JavaJoe_2 » Tue Jun 06, 2006 11:41 am
It looks like plugs aren't replaced until 60k.
Check out this: Maintinance Schedule
BTW I have a set of IK20's for sale, $40 shipped.
Got Boost?? :sweet:
JavaJoe_2
Postby Jon11582 » Tue Jun 06, 2006 12:53 pm
Dealer recommended interval is 60k. But for newer Iridium non-performance plugs, it will probably last well into the 6 figures. Standard Platinum will probably wear out around 90k.
I changed mine out at 60K and i used Denso IK20s (Iridium). I think my stock plugs were Platinum NGKs, but I'm a gen1 guy. They may have switched to non-performance Iridium plugs by Gen2, so stock may last longer.
I dont thinK IK20s are the "non-performance" kind of plugs, so they will probably require the same 60k change interval as platinum plugs.
2000 Black Solara SE
Jon11582
Postby Sap Z » Tue Jun 06, 2006 1:01 pm
dont mean to flame you or anything but you will find tons of info by using search - 'search all terms'
this topis has been discussed a lot so i'm sure u'll get all the info you want.
I recently change mine with denso plat's from autozone for $6.5 per plug. delaership charges $13 for the exact same plug
I changed them myself (even though i'm a noob when it comes to mechanics) u need a special tool which is easy to find too. took about 35 mins for 6 plugs. the back ones a lil harder.
peace
SapZ
V6 SE DWP
Sap Z
Postby Midias » Tue Jun 06, 2006 1:24 pm
Stock were denso double tip plugs when I replaced mine I got double tip BOSCH platinum
Postby Aotoyota » Wed Jun 07, 2006 8:14 am
Thanks for all the replies, I am use to changing spark plugs every two years and just wanted to see what everyone else does plugs.
Aotoyota
Postby Jon11582 » Wed Jun 07, 2006 9:44 am
Midias wrote:Stock were denso double tip plugs when I replaced mine I got double tip BOSCH platinum
If I recall correctly, I think Bosch isnt the best for Toyota platforms, and that we should stick to Denso and NGK. As I remember, Bosch is excellent for American and European platforms, but not good for Japanese.
I forget why I think that though. If anyone can back me up, post it up.
Jon11582
Postby dvdchris45 » Wed Jun 07, 2006 10:36 am
Bosch plugs tend to misfire on Toyota platforms. I remember when I took this fundamentals to auto mechanics class. NGK ALL DA WAY
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Midias » Wed Jun 07, 2006 6:22 pm
dvdchris45 wrote:Bosch plugs tend to misfire on Toyota platforms. I remember when I took this fundamentals to auto mechanics class. NGK ALL DA WAY
I did not know that well I just ordered some IRIDIUM IX plugs I will swap em out
EDIT
I just poped the hood of my dads 03 6 speed Cl-S and it has stock IRIDIUM IX cool :D
Postby Midias » Tue Jun 20, 2006 12:26 pm
Ok all set no more Bosch on any toyota in my family.
Postby alan8888 » Thu Jun 22, 2006 10:40 am
haha my car is almost 50k already
alan8888
