SolaraGuy.com • View topic - Remote start not remote starting...
Postby cklinh » Fri Jun 09, 2006 5:20 pm
Anyone had this happen before? Where it cranks but does not start? Starting with the key is normal. Disconnected battery and then reconnected and tried, same situation.
I know, bring it back to the installer... but just seeing if there's an easy fix I can do before taking it in...
cklinh
Postby ~Spadwaller~ » Fri Jun 09, 2006 5:50 pm
I had the same problem
~Spadwaller~
Postby SolaraGuy22 » Fri Jun 09, 2006 5:52 pm
I believe Krook is the man who can help you troubleshoot it, he is the man at alarms and stuff like that.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby TRD MCV20L » Fri Jun 09, 2006 11:57 pm
You need to adjust the crank time on the alarm. Mine did that before. Once I adjusted it, it worked fine. G'luck
TRD MCV20L
Postby Aotoyota » Sat Jun 10, 2006 8:23 am
transponder bypass
Aotoyota
Postby shocar4 » Sat Jun 10, 2006 9:26 am
if the tach wire is not connected it will crank over but will not always start....the tach wire tells the remote start when the car has started and it will continue to turn it over until it starts...with the tach wire disconnected, it will try just for a few revolutions and then stop because the remote start thinks that the car started...been there done that!
shocar4
Postby gone » Sat Jun 10, 2006 11:18 am
mine has done that before also. It cranks but doesnt start, but then if i wait a minute later it will start. All the lights stay on by the guages so i dont touch it because i know something is still working in there.
gone
Postby cklinh » Sun Jun 11, 2006 5:33 pm
For most responses... it has worked before, so the programming shouldn't be the problem.
As for the "it thinks it has started already"... it's not that either... it'll run through a series of cranks... three times total... so it KNOWS it's not started yet... just can't crank... I too think it has something to do with the transponder bypass, maybe a loose wire or something... anyone know where that might be located/what it may look like?
NEVERMIND! I am such a tard... when I went to put my dash back together last week... I forgot about the little coil of wire that went around the ignition key hole... that somehow ties into the bypass... so yeah... problem solved...
cklinh
Postby TRD MCV20L » Mon Jun 12, 2006 12:38 am
Glad you got it fixed. :D
TRD MCV20L
Postby NeFaRiOuS_SLE » Mon Jun 12, 2006 12:47 am
If your car has an immobilizer (e.g. fatter-than-usual key), you might've forgotten to get a bypass kit. I have a plain version of my key and it does that when I put it in but starts as usual with the coded key.
*Edit: Aotoyota said it. Usually I'd say never mind, but I just added a few details.
Postby cklinh » Mon Jun 12, 2006 8:22 am
Just one last thing
I don't think you guys are reading everything. It WAS working, then it stopped... since everything was working, it meant that everything was installed correctly, i.e., the sensors, the immobilizer bypass, etc...
cklinh
