SolaraGuy.com • View topic - Gen 2 Replacement Bulb Part Numbers
Re: Gen 2 Replacement Bulb Part Numbers
Postby folch52 » Tue Jul 20, 2010 6:06 pm
is there any difference between the normal bulbs and the silverlight bulbs for the turn signals and stuff??
folch52
Postby Jerzey111 » Wed Sep 08, 2010 1:59 pm
hey guys, what bulb is for the drl?? is parking light the drl light in this guide?? thanks
Jerzey111
Postby GzNutz » Wed Sep 08, 2010 2:30 pm
Drl is part of the high beam. 9005
Postby Jerzey111 » Wed Sep 08, 2010 3:44 pm
o ok, thank you very much
Jerzey111
Postby Jerzey111 » Fri Oct 29, 2010 1:07 pm
sorry if this is a dumb question, is there any way to make the drl not low voltage?? i got some really cool looking led bulbs but they dont work in drl mode. thanks
Jerzey111
Postby NewShockerGuy » Sun Dec 19, 2010 11:17 pm
Jerzey111 wrote:sorry if this is a dumb question, is there any way to make the drl not low voltage?? i got some really cool looking led bulbs but they dont work in drl mode. thanks
Or for me is there a way to disable them? I am getting HIR bulbs and since their lffe is rated lower I would prefer not to have them running the entire time...
Thanks,
-Nigel
NewShockerGuy
Postby NewShockerGuy » Tue Feb 15, 2011 2:30 pm
My girl has an 07' Solara Convertible SLE and the 194 bulb for the map lights is not correct:
12V BA9S is the correct bulb if you have a convertible. If you are replacing with LED look for a 57.
Thanks,
-Nigel
NewShockerGuy
Postby gnegroni » Sun Mar 06, 2011 8:38 am
Thanks,
-Nigel
To disable DRL just lower the setting to OFF (1st one down, 2nd one up is Auto)... just turn lights on and off manually.
I believe HIR lights are rated lower than low-beam bulbs, but since you are using the 9011 HIRs (high beam also), I believe you should not have any trouble with them lasting less than the stock high beam (DRL) bulb.
gnegroni
Postby wkbrdr91 » Tue Jan 24, 2012 5:03 am
Ordered all new LED bulbs for the car interior and license plate.... This is how big my DE3175 replacement bulb was... is this right? 31MM is what I ordered.... but clearly that does not fit. Luckily Amazon gave me a full refund and told me to keep it, not like I can use it anyways. It does stay in there just barely because it is so pointy but its gonna fall out the first time I drive the car I bet.
2006 Solara Sport
wkbrdr91
Postby kingkakyle » Tue Jan 24, 2012 2:33 pm
wkbrdr91 wrote:Ordered all new LED bulbs for the car interior and license plate.... This is how big my DE3175 replacement bulb was... is this right? 31MM is what I ordered.... but clearly that does not fit. Luckily Amazon gave me a full refund and told me to keep it, not like I can use it anyways. It does stay in there just barely because it is so pointy but its gonna fall out the first time I drive the car I bet.
same happened to me
so what i did was measure the original bulb, and when i went looking online for one i tried my best to find one of similar length excluding the pointed slimmer ends
so i ended up with a slightly longer bulb, but it still worked
Postby wkbrdr91 » Tue Jan 24, 2012 4:54 pm
same happened to me
So are the ends part of the measurement? Do you remember what size you ordered?
2006 Solara Sport
wkbrdr91
Postby kingkakyle » Tue Jan 24, 2012 6:30 pm
so basically on the original bulb i measured end to end
on the LED i ordered i tried to get the measurement excluding the tips
also what u can do (and what i think i might have done)
is measure the actual size of the light, which is the clear part and try to match it with an LED dome light so that its the same or similar
for some reason i want to say i ordered 61mm, but not sure, its been at least 2-3 years
Re:
Postby TeflonMyk » Wed Sep 17, 2014 5:22 am
cklinh wrote:Who knows the part number of the bulbs in the visor? (On either side of the mirror)
6615F is the part number. 6614F if you want to replace with LED (which may be TOO bright).
TeflonMyk
Postby NewShockerGuy » Thu Mar 31, 2016 10:15 pm
Old thread, but does anyone know how to remove the lower key illuminator? I want to change the bulb since it's burned out but figured I'd ask on how to remove the lower part of the dash...
Thanks,
-Nigel
NewShockerGuy
