SolaraGuy.com • View topic - aftermarket cams for 3mz
Postby Oteck » Wed Jun 28, 2006 10:28 pm
anyone have these? degrees? i know a local here who can make regrinds for $560. any idea how vvti will react to this?
Oteck
Postby PhreakdOut » Thu Jun 29, 2006 4:21 am
Yikes! I'm not sure what your goal is on this one. You probably will yield more power out of good head work versus trying to re-cam the engine and ECU programming.
There is a product on the market that allows you to electronicly adjust the VVT-i cam timing from inside the car. Unless you have other modifications that the ECU has not accounted for, then I'd expect the stock ECU and cam profiles are already them most optimal.
Check this out anyway. It's one of my older postings.
http://www.solaraguy.org/viewtopic.php?t=17269&highlight=
Postby Oteck » Fri Jun 30, 2006 12:21 pm
i plan to buy that later this month but im hopping to squeeze more out using cams
Oteck
Postby Biggi_e » Fri Jun 30, 2006 12:59 pm
hmm im not sure how that will turn out but let us know
