SolaraGuy.com • View topic - how to wire a line from battery to inside the car
Postby alan8888 » Thu Jul 06, 2006 9:45 am
I want to know where can I get a hole ??? Already build install the car ??
or I have to drew it by myself to get a hole. I have 2 x 16gw wire want to connect from the front to inside the car....thx
alan8888
Postby dvdchris45 » Thu Jul 06, 2006 11:01 am
Run it thru the firewall [looks like a big rubber plug with wires in it] ...its directly behind your throttle body
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby alan8888 » Thu Jul 06, 2006 12:32 pm
where is the firewall. ?
alan8888
Postby alan8888 » Thu Jul 06, 2006 12:33 pm
the one near battery ?( egnine right side ) ?? pretty hard to go through
alan8888
Postby theprodigy79 » Thu Jul 06, 2006 12:43 pm
The firewall is the entire separation between you / your dash and the engine bay... It should have pre-drilled ports with wires already running through it to the instruments and such. You can either tap through one of the rubber plugs, as Chris mentioned, or you can drill through and use a ring gromet to protect the cable... 16 Gauge wire is pretty tiny, so you shouldn't have any problems putting it through where the other pre-existing wires already travel through. Just trace out a few and see where they lead.
-James
theprodigy79
Postby Solarafreek » Thu Jul 06, 2006 12:48 pm
SEARCH
Solarafreek
Postby PXLpainter » Thu Jul 06, 2006 1:08 pm
Holy Crap! I'm exhausted from reading that first post!! :o
Postby PhreakdOut » Thu Jul 06, 2006 7:04 pm
alan8888 wrote:where is the firewall. ?
Yikes Alan. :o Are you joking?
Put down the socket wrench and back away. You're going to hurt someone.
Postby NeFaRiOuS_SLE » Thu Jul 06, 2006 10:28 pm
OK I know it sounds a little peculiar, but firewalls are only available with cars that have carputers. You go to Start > Control Panel, then double-click Network Connections, right-click your active connection and hit "Properties", then in the "Advanced" tab, click Windows Firewall.
However, this is OEM protection of Windows XP with Service Pack 2 (SP2) only. To get an aftermarket upgrade, buy ZoneAlarm Pro or run your carputer's data through a router.
Seriously though, a firewall is a "wall" between your engine and the passenger area that is usually of your car's steel chassis that limits the results of an engine explosion or fire to the engine bay.
Postby alan8888 » Thu Jul 06, 2006 11:11 pm
of coz i know what is firewall...for network... i work as a administraor
i also know what is firewall inside the car.... I only thing want to know is where is the hole...i am just too lazy to found it :angel:
alan8888
Postby Down2TheC » Fri Jul 07, 2006 4:49 am
Go to your local Fire Department and ask them if they have any extra firewall for you. 8)
Down2TheC
