SolaraGuy.com • View topic - tire monitor sensor location?
Postby Projex0 » Wed Aug 30, 2006 10:52 pm
hey i was wondering i was searching the forums for tire monitor sensor and couldn't find any info on the sensor location. how does the sensor on the solara work? by ride height? speed? where is it located? is it on the valve stem?cause i tryed reseting it after putting on new rims but it wouldn't go away.
Projex0
Postby MikeATL » Thu Aug 31, 2006 6:01 am
As I understand it:
If one tire spins faster than the other, then that means that the faster spinning tire has a smaller diameter and thus is "under inflated" when compared to the opposite tire.
This triggers the (!) light on the dash
MikeATL
Postby Dekanas » Thu Aug 31, 2006 6:55 am
Yes, MikeALT is right.
ABS sensnors reads the spining.
Dekanas
Postby PXLpainter » Thu Aug 31, 2006 11:58 am
Do a Search - there's a way to reset it with a combination of turning the key on/off and other buttons - posted in a thread here somewhere. ;)
Postby rollaevo99 » Thu Aug 31, 2006 12:10 pm
put the key in ignition turn "on" not all the way
and then press & hold the button under the steering wheel on the left and then wait for 5 seconds until it goes off.
Postby Projex0 » Thu Aug 31, 2006 12:31 pm
so theres no actual unit in the valve stem or attached to the stock rims somehow?
cause i turned it to the on positiion(yes i read the owners manual) and pressed it for 5 seconds and the light didn't do anythingsince its suppost to blink after 5 second
Projex0
Postby rollaevo99 » Thu Aug 31, 2006 1:19 pm
Projex0 wrote:so theres no actual unit in the valve stem or attached to the stock rims somehow?
that's weird? it works for me...... I even did it yesterday on my Mom's toyota sienna. :D
Postby Down2TheC » Thu Aug 31, 2006 2:45 pm
Nope. No special hardware. Just using existing sensors that are there for VSC, TRAC, and ABS.
So I'm guessing the button-presser is your problem 8)
Down2TheC
Postby linmk2 » Thu Aug 31, 2006 5:11 pm
My warning came on today. There was a low tire. Adjusted the pressure, pressed and held the button. All is well now. However, there may be a nail or something in that tire since it was 12 lbs low.
Howard
linmk2
