SolaraGuy.com • View topic - Tutorial on rims needed.
Postby Down2TheC » Fri Jan 26, 2007 6:01 am
There was once a neat post or link to a reference on offset for the Gen2. Can't find it though. Any junior archeologists wish to help dig? I'd like to get something in Gen2 tutorials section that helps with allowable specs. (like the tire size tutorial but for wheels) If the post I'm thinking of can't be found or isn't sufficient, someone with the knowledge should create one. (please)
In the meanwhile, anyone know if I can roll with these and if it would mean rolling fenders or losing turning radius to rubs?
19” is 19x8 +30 mm offset (F) and 19x8.5 +33 mm (R)
Down2TheC
Postby sgunitkc » Fri Jan 26, 2007 3:00 pm
I'm actually running 19x8 with +35 offset and I'm not rubbing at all. BUt! that's because I'm not lowered...if i lower it my back would be totally clear but my front is a lil questionable because right now it's so flush with the fender. The front should be more of a concern for you if you're going to go +30.
sgunitkc
Postby rollaevo99 » Fri Jan 26, 2007 3:03 pm
on my Gen2 I have 19x8.5 with 42 offset and I'm 1 1/2 inch lowered tucked in, even with passanger no rubbing at all
Postby Biggi_e » Fri Jan 26, 2007 3:39 pm
rollaevo99 wrote:on my Gen2 I have 19x8.5 with 42 offset and I'm 1 1/2 inch lowered tucked in, even with passanger no rubbing at all
heh i will be like that soon hopefully during spring.
Postby rollaevo99 » Fri Jan 26, 2007 3:58 pm
cool......I can't wait see it :D
Postby ThatVietGuy » Fri Jan 26, 2007 4:34 pm
http://www.solaraguy.org/viewtopic.php? ... highlight=
Dunno if this is what you mean though
ThatVietGuy
Postby Sebas007 » Fri Jan 26, 2007 10:19 pm
I use 2 tools from 1010tires.com
Wheel Offset Calculator
http://www.1010tires.com/WheelOffsetCalculator.asp
I use my current setup to compare with 18X8 +40 offset
Tire Size Calculator
http://www.1010tires.com/TireSizeCalculator.asp
To figure quickly what is the overall diameter and other measurement.
These are the tire size that fitting more the OEM setup and also have the best choice available.
225/45R18
225/40R19
225/35R20
It may help I think.
Postby crispone » Fri Jan 26, 2007 10:22 pm
I just wear little wheels....
-crisp :evilbat: :drinking:
