SolaraGuy.com • View topic - HID and daytime driving light
Postby Solara08861 » Sun Feb 25, 2007 9:17 pm
I just put HID on my high beams and now my daytime driving lights are not working. Does anyone with hid and high beams had this problem?
I also did low beams 8000k, high beams 8000k and fogs 3000k
Solara08861
Postby NeFaRiOuS_SLE » Sun Feb 25, 2007 9:25 pm
Well, an HID works through a ballast that works off of a certain voltage, so if you have HID high beams, you can officially say goodbye to them.
Postby sahuddleston » Sun Feb 25, 2007 10:39 pm
i ran them on my gen1 with no problem. exact same setup as you. not sure what the problem is though.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby alan8888 » Sun Feb 25, 2007 10:54 pm
u want the hid woyk on day time....
put a harness wire... it will make it work
alan8888
Postby kpxboi0619 » Sun Feb 25, 2007 11:25 pm
this is just my opinion., but,.,.,., HId on high beam? but don't u hardly use those?...? and using HID bulbs for day time light thing..... is waste of bulb life... :(
kpxboi0619
Postby SolaraRolla » Mon Feb 26, 2007 12:32 am
what you can do is disable the DRL. i had HIDs on my corolla low beams. the low beams had DRL so i had to disable it in order for it to work. I had to ground the wire that connects to the emergency brakes. The brake light sign on my dash stayed on even when my brakes were off though.
SolaraRolla
Postby Solara08861 » Mon Feb 26, 2007 10:57 am
How do I fix it with the harness wire?
Solara08861
Postby alan8888 » Mon Feb 26, 2007 1:54 pm
it seem like put a hid on high beam is really uselss ..
if you are use the high beam to flash someone i believe the flashing will be less than 5 sec. The Hid bulb need 5 second to warmup . Everytime you flash someone less than 5 sec is going to reduce the hid bulb life
alan8888
Postby boaclub923 » Thu Mar 08, 2007 7:21 pm
this is it!! this is it!!
this is exactly what happen!!
and this is exactly the reason why i remove HID from high beam..
it was totally waste of money
alan8888 wrote:it seem like put a hid on high beam is really uselss ..
boaclub923
