SolaraGuy.com • View topic - Car gap increases?
Car gap increases?
Car gap increases?
Postby Sin-R V6 » Fri May 04, 2007 12:52 pm
I have a quick question for you guys, i own a 2004 SE. They came with 17" wheels. The tires are 215/55/17.
I got some aftermarket wheels sitting on 215/50/17. When I installed it, the gap seem to increase. Is it because of the tire size?
I have a set of 225/50/17 ready to be slapped on. Is it going to give the same look?
Sin-R V6
Postby Biggi_e » Fri May 04, 2007 12:58 pm
yes your tire gap will increase because you went with a lower profile tire.
Postby ThatVietGuy » Fri May 04, 2007 1:00 pm
That's pretty obvious isn't it? Going from 215/55 to 215/50 means the tire is less tall (5% less), thereby increasing the gap.
http://www.miata.net/garage/tirecalc.html
ThatVietGuy
Postby Sin-R V6 » Fri May 04, 2007 1:02 pm
so the 225/50 wont matter?
Sin-R V6
Postby ThatVietGuy » Fri May 04, 2007 1:10 pm
It'll be pretty close to stock, so ALMOST no gap increase
ThatVietGuy
Postby Sin-R V6 » Fri May 04, 2007 8:36 pm
Hmm wonder if I should just drop the first before I do the wheel change? This is what I get for not getting 20's the first time around blah!!
Sin-R V6
Postby Sin-R V6 » Fri May 04, 2007 9:42 pm
Sin-R V6
Postby RDKamikaze » Sat May 05, 2007 12:42 pm
Don't worry about the gap too much. Once you lower it and give the shocks a week to settle in, you're car will look fine! I have 125/45/18 (I'm pretty sure) on my car and I hated the gap before I lowered it. Once it was lower, it looks nice and snug.
RDKamikaze
Postby Sebas007 » Sat May 05, 2007 1:19 pm
ouch !! Learn to read tire specs ;)
225/45R18
225 = 225mm tire width
45 = 45% of tire width as tire sidewall
R = Radial
18 = 18 inches tires
tire diameter = 2 X sidewall + tire size
25.4mm = 1 inch
so 2 X (225mm*0.45) = 202.5
Bring it back in inches
202.5/25.4 = 7.97 inches + 18 for the tire your wheel has a diameter of 25.97 inches so you have to stand with this measure to get the same gap.
Use this tool it will help you a lot !!
http://www.1010tires.com/TireSizeCalculator.asp
Postby crispone » Sat May 05, 2007 8:19 pm
RDKamikaze wrote:Don't worry about the gap too much.... I have 125/45/18 (I'm pretty sure) .
...wow... :o I bet THOSE will peel out like bananas in a hungry monkeys hands! 8)
BWAAAAAAAAHHHHHhhhhh ha ha ha ha ha!!!
Postby crispone » Sat May 05, 2007 8:21 pm
^^^ Sorry... I couldn't help myself... :arg:
Postby theprodigy79 » Sat May 05, 2007 10:47 pm
Here... I did the work for you many moons ago...
http://www.solaraguy.org/viewtopic.php?t=19601
theprodigy79
Postby RDKamikaze » Sat May 05, 2007 11:48 pm
Thanks for pointing out my flaws, crisp. Now I feel like a moron so I'm going to drink all my fears away. :(
Goodbye, cruel world! :drinking:
RDKamikaze
Postby PXLpainter » Mon May 07, 2007 8:49 am
You should have listened to the salesman at the dealership where you bought your car - and got the GAP insurance they offered - would have solved all your problems! :lol: rofl:
