SolaraGuy.com • View topic - LED Wiring Help
LED Wiring Help
LED Wiring Help
Postby cklinh » Tue May 22, 2007 6:37 pm
So I bought these on eBay...
Pre-wired LED's
they're LED's prewired with a resistor...
I'm hooking 5 or 6 of them up together for car use... for all you smarties out there, should I wire them up in series or in parallel?
I thought series would work, but when I tested them out, it seemed to be dimmer... wiring in parallel seems to make everything as bright as possible, but there is a drawback right? (heat, maybe?)
Circuits wasn't always my best subject, and I'd hate to have to bust out the books :)
cklinh
Postby Sentinel » Tue May 22, 2007 6:54 pm
When you wire stuff up in series each item gets a fraction of the voltage (it's divided evenly if the resistances are the same) whereas stuff in parallel all see the same (full) voltage. Thats why they're brighter in parallel.
If you have enough LEDs in series you shouldn;t need the resistor. Do you have a meter to find their resistance?
You really need to know the voltage rating of an individual LED. That will determine the best way to wire them. You may end up with a combination series-parallel circuit.
I take it the mfg. is not helpful?
Sentinel
Postby cklinh » Tue May 22, 2007 7:09 pm
Haven't talked to them yet... but since they were marketing the LED/resistors as for car use, I'd imagine they were designed for 12 V.
Then, wiring in parallel will allow me to use them all together without removing the resistor. But is there a drawback to wiring them in parallel?
LED Info:
# Wavelength: 620nm-630nm
# Luminous Intensity-MCD: Min:40000cd Max: 60000 mcd
# Reverse Voltage:5.0 V
# DC Forward Voltage: Typical: 12.0 V Max: 15.0V
# DC Forward Current:20mA
cklinh
Postby Sebas007 » Tue May 22, 2007 8:31 pm
Are you planning to do the 3rd brake light with LED as Milton did ?? If so I'm interested in DIY ! ;) I quickly check how can access the interior of the 3rd brake light...I didn't find.
Postby cklinh » Tue May 22, 2007 8:42 pm
:D
If I get it to work, I'll have a tutorial.
I've gotten the rear deck off before while replacing the speakers, and it didn't look like that much of a problem to remove the lens/reflector on the brake light. I was planning on having something that plugs into the 194 bulb socket... just gotta figure out wiring :)
cklinh
Postby cklinh » Wed May 23, 2007 6:05 am
Response from seller is to wire them in parallel.
cklinh
Postby Sebas007 » Wed May 23, 2007 6:27 am
Nice stuff ! :)
By the way, thanks for your hint on the flasher resistor unit !! Gone in 60 seconds !! :P
