SolaraGuy.com • View topic - '04&'07 interchangeability
Postby cns » Wed May 30, 2007 11:41 am
is it possible to some parts from 07 to 04, Im intresting in
- front bumper
- rear lights
- gauge
To talk a lot doesnt mean to tell a lot!
cns
Postby Biggi_e » Wed May 30, 2007 12:43 pm
front bumper im pretty sure it will fit without problems
taillights will fit with modifications since the reverse light is in the rear bumper
gauge cluster im not sure of.
Postby cns » Wed May 30, 2007 1:34 pm
Biggi_e wrote:taillights will fit with modifications since the reverse light is in the rear bumper
You mean they will fit if Ill install them i pair with rear bumper + rear ligts mounted in it?!
cns
Postby Down2TheC » Wed May 30, 2007 1:34 pm
Tail light upgrade is documented in the tutorial section. I would think bumber should be close... but ick! And you'd be blazing a new trail with the guage swap. Chances are it would be pug and play since the changes are merely cosmetic. If you could get a look at the EWD for both years, you could check the harness connections to be sure.
Down2TheC
Postby cns » Wed May 30, 2007 1:47 pm
Down2TheC wrote:Tail light upgrade is documented in the tutorial section.
Can't find it...
cns
Postby rollaevo99 » Wed May 30, 2007 2:06 pm
Can't find it...
are you sure????? here, I'll post the link for you to make it easier :roll:
http://www.solaraguy.org/viewtopic.php?t=27454&start=0
Postby Down2TheC » Wed May 30, 2007 3:43 pm
Must have been the title that threw ya. 8)
Down2TheC
Postby Biggi_e » Wed May 30, 2007 5:30 pm
Down2TheC wrote:Must have been the title that threw ya. 8)
:rofl:
Postby NightRider » Wed May 30, 2007 10:50 pm
newbs :)
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
