SolaraGuy.com • View topic - Special Trick To Replacing Right Fog Bulb?
Postby Gadgetjq » Thu May 31, 2007 1:43 pm
I'm looking at replacing the stock bulbs with Nokya's and know quite a few forum members have been here, done this.
High beam/low beam piece o' cake. Left (drivers side) fog is a little tight reaching through the grille but I can get fingers on it. The right (passenger) side though.....I dunno.
Before I just start experimenting with panel removal is the right side easy to reach if I remove the right side belly pan or is there another way (besides hiring a 6 year old) to reach that puppy? Maybe it's just a matter of persistence?
If there's a trick I'm ready to hear it before actually ordering the bulbs.
Thanks!
Gadgetjq
Postby Ruski » Thu May 31, 2007 1:46 pm
Yea theres a trick theres three screws you take them off and pull the panel down and it allows you to gain access to the bulb.. the panel im talking about has a circular hole when you look up when under the car.
Postby cklinh » Thu May 31, 2007 1:47 pm
Not really a trick... I just went through the wheel well. Turn the wheels to the opposite direction that you're working on, remove a few clips/plastic holders, and you can partially peel back the plastic liner.
The underside is another way to go, but you have to remove more screws.
cklinh
Postby Gadgetjq » Thu May 31, 2007 2:40 pm
Thanks gents, that's very helpful. At least now I know for sure the only way to the goal is through panels.
Cheers
Gadgetjq
Postby PXLpainter » Thu May 31, 2007 8:46 pm
Since I tore-out all that crazy plastic crap under the front end, I can just reach right under and swap mine out now! :D
Postby NightRider » Fri Jun 01, 2007 8:26 am
I went through under. Took me 10 mins to swap out both bulbs. It was a sinch! BTW I put in the Nokya "yellow" bulbs on my fogs now :)
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby PXLpainter » Fri Jun 01, 2007 8:31 am
^^ Same here. I know you'll see me bitch about the yellow fogs in other threads but I finally caved in after seeing a few Lexus and Bimmers in my area with them - and I just couldn't stand to see the OEM dull color against my HIDs anymore! Never could find a bulb that matched close enough to my HIDs either, so I just figured WTF! :roll: Now I'm happy with them, though it's mostly for looks than actual function, since the HIDs overpower any real light they give off.
Postby NeFaRiOuS_SLE » Fri Jun 01, 2007 10:07 am
^^But CRUCIAL when you get the cheap HID replica halogens; light output is crap without them!
Postby Solara08861 » Fri Jun 01, 2007 10:52 am
Just put 3000k HID in your fogs and you would love them. The lighting its so much better. I love driving with them.
Solara08861
Postby Gadgetjq » Fri Jun 01, 2007 11:04 am
NeFaRiOuS_SLE wrote:^^But CRUCIAL when you get the cheap HID replica halogens; light output is crap without them!
Which brings up another question. I've noticed Nokia bulbs are (roughly) half the price of PIAA for what 'appears' to be a comparable bulb. On the other hand most of the manufactuers cite the "wattage" output of their bulb rather than actual lumens from a specific distance.
Is there a measurable difference between brands in light output and lifetime to warrant spending quite a bit more on PIAA or other name brand rather than something like Nokia?
Gadgetjq
Postby sgunitkc » Fri Jun 01, 2007 4:26 pm
PXLpainter wrote:^^ Same here. I know you'll see me bitch about the yellow fogs in other threads but I finally caved in after seeing a few Lexus and Bimmers in my area with them - and I just couldn't stand to see the OEM dull color against my HIDs anymore! Never could find a bulb that matched close enough to my HIDs either, so I just figured WTF! :roll: Now I'm happy with them, though it's mostly for looks than actual function, since the HIDs overpower any real light they give off.
Lol jeff you finally decided to go w/ nokya yellow fogs...i just remember you always asking why people would do such a thing :lol:
I actually have the yellow fogs myself and IMO I think there definitely is a decline in the light output and also the quality of the bulbs. I only got them because I wanted some cheap alternative from stock until they burn out and I upgrade to HID or somewhat. The thing is...I've had it for couple years now (2-3) and it's still going good
:o
sgunitkc
Postby NightRider » Fri Jun 01, 2007 11:22 pm
Spending 85 some odd dollars for a pair of bulbs is a bit much for me. After having PIAA's in my previous car for a bit and having them burn out every couple months wasn't worth it.
Injen polished SRI
TRD FSB 6000K HID's
NightRider
