SolaraGuy.com • View topic - Brake pad
Brake pad
Brake pad
Postby shobo » Fri Jun 01, 2007 1:15 pm
I just hit 100,000 miles on my 2004 solara and I need to change the brake pads. Can anyone suggest any good brake pad? I was thinking of going with ceramic material; something like Akebono brake pad.
http://performance.thepartsbin.com/bask ... andid=3961[/img]
shobo
Postby Biggi_e » Fri Jun 01, 2007 1:17 pm
wow 100,000 already?? wtf! im right by 70,000 on my 04! jeez i want to see a picture of your odometer lol. anyways i just use oem brake pads.
Postby shobo » Fri Jun 01, 2007 1:18 pm
shobo
Postby cklinh » Fri Jun 01, 2007 3:43 pm
Holy crap! I'm approaching 27,000 miles...
cklinh
Postby NightRider » Fri Jun 01, 2007 11:23 pm
eh I just hit 31k :)
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby sgunitkc » Sat Jun 02, 2007 1:49 pm
Does brake pads even make that much of a difference? I thought it was the rotors or the big brake kits that does more of the improving in braking. I just always get the Toyota OEM brake pads.
sgunitkc
Postby alan8888 » Fri Jun 29, 2007 10:54 am
i got 55000 last year......now is only 57000....i only drove 2000 miles in 8 months :-)......................gas is too expensive right now...i drive my sister's pirus all the time :-)
alan8888
Postby PXLpainter » Fri Jun 29, 2007 11:17 am
I got mine with the new rotors from R1 Concepts
http://store.r1concepts.com/Brake%20Pad ... ta/Solara/
I've been very pleased with the performance and wear - even on drilled/slotted rotors. :up:
Postby Down2TheC » Sat Jun 30, 2007 7:16 am
^^^ Damn! Those prices aren't bad. When it's time to paint the cals I may have to swap rotors. That would be easier than trying to clean up the ones I have. Can they machine a slotted rotor when it's time to change the pads?
Down2TheC
Postby sydemoid » Sat Jun 30, 2007 8:28 am
In all honesty...
If you want stronger stopping power in the long haul, carbon metallic is the way to go.
Do your research, and you will see that some pads require a warm up period before they wok @ 100%...
If you have slotted rotors... DO NOT use EBC kevlar pads... I had them on my car after ceramics, and they overheated too easily, causing erratic braking (Not cool!)
I have cross drilled/slotted rotors on my ride, and currently Im liking the Carbon/Metallic pads.
Always a pro/con with these things, the pads are the only "tuneable" part of our braking system. Metallic pads create more brake dust, handle more abuse, and need to be heated to work right.
Oem pads are great, but for spirited driving, they will wear out quicker.
Stick to AXXIS, HAWK, AKEBONO pads, and you will not regret the choice, upgrade your brakelines to Goodrich stainless stell braided lines, and upgrade to DOT 4 (currently using racing formula by ARE)... your brakes will stop on a dime, and give you some change.
my 2 pennies.
-D
sydemoid
Re: Brake pad
Postby QuickSEV6 » Sat Jun 30, 2007 8:37 am
shobo wrote:I just hit 100,000 miles on my 2004 solara and I need to change the brake pads. Can anyone suggest any good brake pad? I was thinking of going with ceramic material; something like Akebono brake pad.
Thats probably your best choice.
Akebono ceramics. Thats what I have.
Be sure to check out tirerack.com
Postby godshippy » Sun Jul 01, 2007 12:27 pm
Currently the number one brake pad out on the market is Performance Friction. They make a carbon metallic pad that reduces noise and increases braking performance (both stop and feel).
As far as the brake lines are concerned...EHHH, I don't buy it...unless you increase the size of your calipers to like a 2-6 piston caliper it's not going to improve much besides appearance.
(I work as the store manager at a tire/service/repair shop in Central California, 7 years exp.)
godshippy
