SolaraGuy.com • View topic - Replacing the H10 with the 9005 for more light!
Postby philosophicaljt » Wed Aug 08, 2007 4:59 pm
I enjoy lighting. I wanted to get more lighting for my fog lights, without an HID retrofit, mostly because I cannot afford it.
But before anyone does this, I would advice you to check and see how many amps of difference there is between the two. I am going to go ahead and leave this in, but I am a risk taker! Again, I would not recomend this to everyone, unless you check the amperage difference.
Here is the stock H10 foglight bulb
Here is a comparision between the stock bulbs:
Here is the comparision after the 9005 is modified:
I'll get some wall shots and some comparision pics in a minute or two. Stock bulb is on the drivers side. Modified 9005 bulb is on the passengers side.
Its hard to tell in these pics cause its not very dark yet, but there is a noticable difference. I'll post more pics as soon as it gets dark. and here they are:
This last pic looks like it has more glare, but with my eyes, I noticed no more glare.
Last edited by philosophicaljt on Thu Aug 09, 2007 4:23 am, edited 3 times in total.
2004 Solara SLE V6
Search
philosophicaljt
Postby philosophicaljt » Wed Aug 08, 2007 5:31 pm
If you are interested in changing your headlight bulbs into brighter bulbs, go here:
http://www.solaraguy.org/viewtopic.php?p=395899
2004 Solara SLE V6
Search
philosophicaljt
Postby kpxboi0619 » Wed Aug 08, 2007 8:42 pm
I don't see the difference.......????
kpxboi0619
Postby philosophicaljt » Thu Aug 09, 2007 4:22 am
^^Its not huge. But its there. When I install my yellow bulbs, it might make more of a difference. thats next :)
2004 Solara SLE V6
Search
philosophicaljt
Postby gnegroni » Mon Aug 13, 2007 11:21 am
I think we are talking less than 1 amp difference...
gnegroni
Postby philosophicaljt » Mon Aug 13, 2007 1:17 pm
I believe the stock bulb is only 45w, and the 9005 is a 65 or a 55w I believe.
2004 Solara SLE V6
Search
philosophicaljt
Postby philosophicaljt » Wed Aug 15, 2007 7:07 am
K, i did the incredibly basic math....lol
H10 bulb: 42w and 3.5amps
9005 bulb: 65w and 5.4amps
so a difference of 1.9 amps. Not huge. Since its a 10amp fuse, I believe we are fine :) But I am no expert. Just more information.
2004 Solara SLE V6
Search
philosophicaljt
Postby philosophicaljt » Wed Aug 22, 2007 10:08 pm
here is another photo, its a little easier to tell the difference here:
2004 Solara SLE V6
Search
philosophicaljt
Postby gnegroni » Thu Jan 17, 2008 7:57 pm
So, are all 9005s 65w? or usually 55w?
gnegroni
Postby philosophicaljt » Thu Jan 17, 2008 8:23 pm
65w stock. And the 9006 is 55w.
2004 Solara SLE V6
Search
philosophicaljt
