SolaraGuy.com • View topic - Lowering my car
Lowering my car
Lowering my car
Postby SHOLARA » Sun Sep 09, 2007 11:22 pm
Does anyone know where i could find a tutorial on how to remove the stock springs from a gen 2, and then putting in after market springs. My main concern is how to remove the springs, I know the general idea, but I just want to make sure.
Thanks in advance
SHOLARA
Postby ThatVietGuy » Sun Sep 09, 2007 11:35 pm
The one real item that I think is necessary is the spring compressor.
Slap the compressor on the stock spring, lock it down, unbolt the strut mount, and off it goes.
Then bolt the compressor to the aftermarket spring and reverse the process.
ThatVietGuy
Postby philosophicaljt » Mon Sep 10, 2007 5:24 am
ThatVietGuy wrote:Slap the compressor on the stock spring, lock it down, unbolt the strut mount, and off it goes.
not the safest method, but that does work. make sure that the spring doesn't hit anything on the way out/down, like brake lines or sensors of any sort.
2004 Solara SLE V6
Search
philosophicaljt
Postby Solarafreek » Mon Sep 10, 2007 5:55 am
^^I am sure he means with the strut and spring off the car.
Solarafreek
Postby unbalancedwood » Mon Sep 10, 2007 6:04 am
^ funny you should mention that cause I ACCIDENTLY did that when i first tried lowering my car.
Was frustrated that the assembly wouldnt come out...so remember kids...take the whole thing off your car (mount, spring, and strut) before trying to take off the spring/use a spring compressor...
unbalancedwood
