SolaraGuy.com • View topic - Look wat i saw today..Gen 2 Solara with dual exhaust
Postby lemmez » Fri Sep 21, 2007 6:19 pm
It actually looks clean huh? The sound ton of the exhaust was real soft (no rice). I couldn't even hear it over my rental car 07 maxima se. Btw i got hit a couple days ago hence the rental. :cry:
lemmez
Postby iinokturnolii » Fri Sep 21, 2007 6:23 pm
nice! i want one, actually 2 :lol:
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby Jakecallun20 » Fri Sep 21, 2007 7:37 pm
thats pretty sweet. bet it sounds nice, wonder what brand they are? :lol:
Postby Solarafreek » Fri Sep 21, 2007 7:48 pm
That looks terrible....
Solarafreek
Postby lilmike2069 » Fri Sep 21, 2007 8:05 pm
^ I agree... the right tip should be further to the right for starters
lilmike2069
Postby Somedude » Fri Sep 21, 2007 8:59 pm
I think the best example of Gen 2 with dual exhaust is Mike T's Solara, it looks really nice.
This Solara:Image
just looks horrible, the exhaust holes looks like something was jammed up in it forcibly and made the holes bigger.
Somedude
Postby iinokturnolii » Fri Sep 21, 2007 9:03 pm
but it sure as hell look better than these that i saw...
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby ClassySolaraGuy » Sat Sep 22, 2007 12:14 am
iinokturnolii wrote:but it sure as hell look better than these that i saw...
Wzup Boi!
Jes & I saw the same ride a long while ago too! LMAO!
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby iinokturnolii » Sat Sep 22, 2007 2:34 am
^^^LOL! whats up bro! the muffler looks like a pairof lopsided tits... :lol:
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby PXLpainter » Sat Sep 22, 2007 11:42 am
Geezes... why ever try to do this if you can't do it right? :roll:
Tips are off-center and look way to low - should be molded up into the bumper shirting more to look right.
The Gen 2 look wasn't designed for dual tips int he first place and the original single tip is actually a little to low as it is.
If I keep mine long enough, I may actually try to modify it to be right... like this:
But this will take modifications to the mounts as well as the rear bumper, but will look a lot cleaner in the end. (pun intended) ;)
Postby philosophicaljt » Sat Sep 22, 2007 11:48 am
^^I'd like it more if the tips were closer to the sides and not the cneter. Aka, move the exhaust tips farther outward.
2004 Solara SLE V6
Search
philosophicaljt
Postby Solarafreek » Sat Sep 22, 2007 12:11 pm
PXLpainter wrote:Geezes... why ever try to do this if you can't do it right? :roll:
Thats niiiiice.
Solarafreek
Postby PXLpainter » Sat Sep 22, 2007 6:33 pm
Actually, I'd like to get the up a little higher than that even, but would have to look all around and get the best fit. Don't want have the muffler actually touching the frame or anything. ;)
Postby philosophicaljt » Mon Sep 24, 2007 4:27 am
pxl you have a beautiful car. but I do believe that rear exhaust would slaughter it unless you moved the tips more outward. They just look too narrow like that. Do you see how they are between the tailights? I think they need to be "inside" the tailights. Make sense? If they each moved outward about 6" (real life, not photo sized) it would be perfect.
Anyone else understand/agree?
I double commented, because I think it would make our cars look really mean, assuming you also have the SE Sport Lip kit.
2004 Solara SLE V6
Search
philosophicaljt
Postby PXLpainter » Mon Oct 01, 2007 5:47 am
^^ Have you even looked under your car at all?
Unless you somehow relocate your muffler further up-stream in the system that's not gonna happen! :roll:
