SolaraGuy.com • View topic - Rim/Tire Size Question
Postby XEusioN » Fri Oct 26, 2007 4:54 pm
Hey Guys, quick question.
I've searched left and right today looking for an answer to this one but didn't turn up anything useful.
I'm looking at picking up a set of 19x8.5 rims, +45mm offset with 235mm tires, is this going to be a problem on an unlowered Solara? I'm mostly worried about the offset and width of the rim.
Any feedback is appreciated :)
XEusioN
Postby ---CAMRAZY--- » Fri Oct 26, 2007 5:07 pm
Lowered or not, that offset is a little high, but a set of 10 or 15mm spacers can take care of that problem, especially for the rear.
Postby XEusioN » Fri Oct 26, 2007 5:14 pm
If I went with spacers, I'd need longer studs right?
XEusioN
Postby ---CAMRAZY--- » Fri Oct 26, 2007 5:21 pm
If you buy H&R's, they come with longer studs, so do Ichiba usa and kics...
Are you going to buy the G-games that are on v6p??
Postby Down2TheC » Fri Oct 26, 2007 11:11 pm
fwiw, my 8.5" 19s w/ a 38 offset (rear only) fit nicely. They poke a bit so the fenders had to be chopped. But 6 months and I've only felt one rub on a dip doing 75.
8.5" up front might be a prob though. I have 8" up front with no issue.
Down2TheC
Postby XEusioN » Sat Oct 27, 2007 6:30 am
---CAMRAZY--- wrote:If you buy H&R's, they come with longer studs, so do Ichiba usa and kics...
Nope, Axis Hiros on V6P :)
I'm gonna hold off for now, I don't have time to monkey with spacers or pressing studs :(
XEusioN
Postby ---CAMRAZY--- » Sat Oct 27, 2007 8:42 am
^^^If you are getting them at a good price, I would go for it. Then start looking for a set of 15mm spacers for the rear, the front will be okay.
Down2TheC wrote:fwiw, my 8.5" 19s w/ a 38 offset (rear only) fit nicely. They poke a bit so the fenders had to be chopped. But 6 months and I've only felt one rub on a dip doing 75.
Your problem is the tire size you are currently running....
Postby XEusioN » Sat Oct 27, 2007 2:42 pm
1400 shipped with 75% tread falken tires isn't a bad price, but the damage on the rims looks worse than it was originally described :(
2005 Toyota Tundra SR5 V8
2004 Toyota Solara SE
7.1L - 12 Cylinders :: 442hp/488lb-ft
XEusioN
Postby PXLpainter » Sat Oct 27, 2007 10:46 pm
HFC!!! :o What did they do to those rims???!!!!
Postby Down2TheC » Sun Oct 28, 2007 6:06 am
Looks like they were raped by an impact driver. Ouch.
Down2TheC
Postby PXLpainter » Sun Oct 28, 2007 7:59 pm
Ass wipes at America's Tire only stripped 3 studs at my last visit. Impact drivers are the DEVIL! :evil: - WTF do they still use them on forged rims?
I try to watch them like a hawk, but the last time was a 2-3 hour wait and had to leave the car so even though I warned them not too, it's obvious they fugged them up when we went to remove the front wheels and I don't have proof unfortunately.
NEVER NEVER NEVER go to America's Tire Co.!!! Bastards!! :evil:
Postby kingkakyle » Sun Oct 28, 2007 8:49 pm
^^^ wow, the america's tire i went to they did it by hand, or rather without an impact gun
guess it depends where u go xP
Postby PXLpainter » Wed Oct 31, 2007 7:57 am
^^ I just spent $160 to fix a problem that America's Tire caused on my ride. They fuX0rd up all the studs on the two front wheels and had to have 3 studs replaced and all re-threaded with new nuts - just because some idiot used an impact wrench.
The Firestone I went to up here in Ventura said that a couple places have an open PO for repairing AT f-ups and get them in daily. They are totally known for being as bad as Sam's Club/Costco for not knowing what they are doing or just being lazy. :roll:
That being said - they are part of the Discount Tire chain and are all independently owned, and I've had much better luck in the past with DT than I have AT.
