SolaraGuy.com • View topic - 2007 headlights.
2007 headlights.
2007 headlights.
Postby gEkAe818 » Wed Nov 21, 2007 2:55 am
i've read on here that some of you have tried the 2.5 headlight i want to know if they fit without any problems???? Also i 've been wanting to get a stock navigtion system for my 04 but the dealer says they don't know if it will work because they all come with diferent plugs?
gEkAe818
Postby Sebas007 » Thu Nov 22, 2007 5:47 pm
I choose to go with Kenwood Nav...I think it offers more plug-n-play accessories and have a better nav display and is cheaper. I will have mine installed tomorrow ! :D
http://www.solaraguy.org/viewtopic.php?t=36671&start=0
About the Gen 2.5 HID...I'm almost curious about it
Postby gEkAe818 » Fri Nov 23, 2007 12:55 am
What aabout 07 headlights do they just fit in like the tailights????? or do i need to modify any thing??
gEkAe818
Postby **PoshPepper** » Fri Nov 23, 2007 10:19 am
gEkAe818 wrote:What aabout 07 headlights do they just fit in like the tailights????? or do i need to modify any thing??
As far as anyone knows they are direct plug and play. If you are getting just the housing, they will bolt right on since none of the sheet metal was changed.
The only thing that will not work is the manual height adjustment feature that they come with (a knob in the car that allows you to lower or raise where the headlights will hit). You would have to figure out a way to wire that up.
But the actual housings should fit no problem.
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby philosophicaljt » Sat Nov 24, 2007 2:49 pm
They fit perfectly. If you get the HID's out of the Gen2.5,s you will have to play with the wiring, but everything still bolts right up.
2004 Solara SLE V6
Search
philosophicaljt
Postby gEkAe818 » Tue Nov 27, 2007 10:36 pm
has anyone tried this before?
gEkAe818
Postby ---CAMRAZY--- » Tue Nov 27, 2007 10:40 pm
gEkAe818 wrote:has anyone tried this before?
None of these broke fools have, so be the first.
