SolaraGuy.com • View topic - STOCK FSB
STOCK FSB
STOCK FSB
Postby 47TH_Ronin » Thu Jan 24, 2008 8:27 pm
i was just wondering guys....is the Stock FSB really any different from the TRD FSB? better worse, or same?
"WILL POWER...IS NO MATCH FOR HORSE POWER"
47TH_Ronin
Postby Jakecallun20 » Thu Jan 24, 2008 8:27 pm
I think the TRD is thicker and stronger. Oh and its ajustable
Postby Sparky5e » Thu Jan 24, 2008 9:12 pm
I think you had a typo. TRD (to the best of my knowledge) doesn't make a FSB or anyone else either. For the gen 2 only a RSB and a Front Tower Brace are available from TRD. They do offer other stuff but not part of this topic.
Both are worth it especially on a convertible. Mine was so loose it was scary before installing them and is night and day difference with them. The RSB is adjustable with 3 positions which enables better sway control while maintaining the same ride quality or stiffening it up a little.
07 SLE Convertable
Blue Streak Metallic
Sparky5e
Re: STOCK FSB
Postby ClassySolaraGuy » Thu Jan 24, 2008 11:06 pm
47TH_Ronin wrote:i was just wondering guys....is the Stock FSB really any different from the TRD FSB? better worse, or same?
Are you talking about this:
Front Strut Tower Brace
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby PXLpainter » Fri Jan 25, 2008 12:56 am
The TRD FSTB (Front Strut Tower Brace) makes a HUGE difference in handling (especially noticeable on the convertibles) as it is made with solid steel bars instead of rolled sheet metal that the OEM ones are made of.
There should be pics/info on here... try a Search.
Postby 47TH_Ronin » Fri Jan 25, 2008 8:45 am
Yea Yea Yea, you guys knew what I was talking about lol. Sorry, came back from Iraq a few months ago....thought I got rid of all the sand, guess some is still in my brain. Anyhow, yea, the tower brace...is ther a BIG difference between the OEM one is have and the TRD one. Im sure the after market one from TRD is better, but is it so much better that I should remove the factory one and spend a couple hundred on he TRD one?
47TH_Ronin
Postby [SMAN] » Fri Jan 25, 2008 9:16 am
There are plenty or articals out there on the idea of strut tower bars and how they work. The basic principle is this. When you lower the center of gravity, the top has of the U shaped frame has a tendency to flex. By attaching the FSTB, you change it from a U shape to a Box shape. While our stock car can benifit a bit from it, it is much more beneficial with a lowered car as there is more flex at the top of the struts. The TRD one is build out of solid material while the factory one is out of sheet metal. This will make it stiffer and more resistant to flex so it will help. Weather or not you notice it is up to how you drive. If it's your only mod, i doubt you'll notive a difference, but if you combine it with some lowering springs and a rear sway bar, you will have a much more rigid setup.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby PXLpainter » Fri Jan 25, 2008 9:47 am
47TH_Ronin wrote:Yea Yea Yea, you guys knew what I was talking about lol. Sorry, came back from Iraq a few months ago....thought I got rid of all the sand, guess some is still in my brain. Anyhow, yea, the tower brace...is ther a BIG difference between the OEM one is have and the TRD one. Im sure the after market one from TRD is better, but is it so much better that I should remove the factory one and spend a couple hundred on he TRD one?
Well - I answered that in my post right before yours...
Got Sand? ;)
Postby gnegroni » Fri Jan 25, 2008 9:54 am
Is the strut tower brace heavier than stock?
gnegroni
Postby PXLpainter » Fri Jan 25, 2008 8:04 pm
:think: Geezes... is anybody actually reading the responses here or just posting for the hell of it? :roll:
Let's see... rolled sheet metal tubing (OEM) vs solid steel bars welded together (TRD)... hmmm
Heavier?
You tell me.
Stronger?
You tell me.
Perform better than OEM?
Already told you!
:drinking:
Postby kingkakyle » Fri Jan 25, 2008 9:35 pm
thanks sman for the info...
maybe its time for me to upgrade my fstb :D
Postby Down2TheC » Sat Jan 26, 2008 10:06 am
Just don't go there until you have the RSB. That makes the HUGE difference in handling. FSTB is second on the list of cheap/easy suspension tweaks.
Down2TheC
