SolaraGuy.com • View topic - Clutch question
Clutch question
Clutch question
Postby solara caper » Sat Feb 02, 2008 11:56 am
Can any one tell me if I can use a tc stage 3 clutch on a solara trans for a 2azfe the dealer ship told me it couldn't be done because the trans has different part #'s , I wasn't shore if I should believe him because when I said 2azfe he looked at me like I had 10 heads , then i said 2.4L and he was like ,oh oh O.K.
solara caper
Postby Turbosolara » Sat Feb 02, 2008 12:56 pm
i am not sure if it will fit but i know tc has different gearing ratio and i am not sure if the tranny is the same.
but are you turboed? why do you need stage3 clutch? if you dont have heavy mod, you do not need performance clutch. in fact, i heard most of people runs performance clutch on their daily drive car regret about it because it is too hard to drive.
Postby solara caper » Sat Feb 02, 2008 2:47 pm
I am curently in the process of getting every thing needed to turn on the boost , I plan on fuly buildin the motor , for the mean time I'm running N\A with some intenal mods and bolt ons ona auto trans that doesn't seem to slip at all ,somthing I found strange with my 4speed was that it doesnt shift untill 6700 rpm , but I planed on swaping it with the tc trans but theres just too much moding to be done and I have no skills when it comes to tranys so iwas gonna have a shop put a 5 speed in in the summer when i get home
solara caper
Postby gnegroni » Sun Feb 03, 2008 11:17 am
Your auto tranny doesn't shift until 6700 rpm? Does it sound like its shifting at 6700rpm, or similar to how it shifted straight from the dealer?
Oh, I'm not sure what exactly is the change, but the tC transmission has nearly identical gear ratios, suckier highway economy (29 vs 33)... I guess its the higher 5th gear ratio and final drive
http://www.toyotanation.com/forum/showthread.php?t=121453
tC:
1st Gear Ratio: 3.538:1
2nd Gear Ratio: 2.045:1
3rd Gear Ratio: 1.333:1
4th Gear Ratio: 0.972:1
5th Gear Ratio: 0.775:1
Final drive 4.24
Solara 2.4 manual:
3.538:1 first gear ratio
2.045:1 second gear ratio
1.333:1 third gear ratio
0.972:1 fourth gear ratio
0.731:1 fifth gear ratio
Final drive 3.94
gnegroni
