SolaraGuy.com • View topic - 2006 Solara Kaixen HID issue
Postby jkotulak » Sun Feb 10, 2008 5:44 pm
I recently installed a Kaixen 6000k HID kit in my 2006 Solara. It works great except my DRLs no longer work. Also, when I flash my high beams, only the right high beam bulb flashes. Could this be a grounding problem? I am using a relay to supply power to the ballasts. Thanks in advance.
jkotulak
Postby [SMAN] » Mon Feb 11, 2008 9:13 am
My DRLs work fine with my HIDS (allthoguh i have regular bulbs in my high beams). Do the both come on when you turn on your highs normal? Also didy ou install HIDs into your highs aswell?
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby jkotulak » Mon Feb 11, 2008 9:17 am
I am using the stock bulbs for the high beams. When I put the light switch into the "DRL" mode, neither comes on. When I turn on high beams, both HIDs stay lit (which I think is correct) but only the right high beam turns on.
jkotulak
Postby PXLpainter » Mon Feb 11, 2008 12:46 pm
Yikes... sounds like a wiring/connection prob...
Bump for some help from someone who's experienced this before.
Postby michaels artic frost » Tue Mar 11, 2008 11:32 am
Any updates on this issue? I've got some aftermarket hids and they've been great.
Updated 06/01/12: Michael T's
Postby boaclub923 » Wed Mar 12, 2008 3:39 pm
did u check the fuse for high beams?
and perhaps, check the lighbulb?
did u upgrade ur high beam to super white light bulb?
those upgraded bulbs could possible burn ur light bulb socket.
unplug the socket and double check the shape of socket.
on all new toyota/solara
if one of the lighbulb on high beam is not function correctly, such as light bulb burn, it will force itself to shut off DRL function.
boaclub923
Postby geminiz » Wed Mar 12, 2008 4:31 pm
jkotulak wrote:I am using the stock bulbs for the high beams. When I put the light switch into the "DRL" mode, neither comes on. When I turn on high beams, both HIDs stay lit (which I think is correct) but only the right high beam turns on.
When you turn on your high beams, the low beams are not suppose to turn on. Only your high beams are suppose to stay on.
2006 Solara SE (2.4L w/5 speed automatic)
Lunar Mist
geminiz
Postby boaclub923 » Wed Mar 12, 2008 6:22 pm
um... my lowbeam stays on when i turn on highbeam,
but foglight will be off
boaclub923
Postby kingkakyle » Wed Mar 12, 2008 7:21 pm
boaclub923 wrote:um... my lowbeam stays on when i turn on highbeam,
+1
Postby PXLpainter » Wed Mar 12, 2008 9:36 pm
+1
+2 - they're designed to do that! ;)
Postby geminiz » Thu Mar 13, 2008 3:03 pm
Sorry. I should've checked to make sure before confusing anyone. I better go check my lights tonight.
Lunar Mist
geminiz
