SolaraGuy.com • View topic - cp-e tuneable / non-tuneable
Postby white_solara » Mon Feb 11, 2008 3:08 pm
hi i was just wondering what the difference is between the cp-e tuneable and non tuneable? Im thinking of getting it like sometime this week..for the guys who has cp-e how much power approx. did y'all gain?
white_solara
Re: cp-e tuneable / non-tuneable
Postby SolaraBlue » Mon Feb 11, 2008 3:19 pm
white_solara wrote:hi i was just wondering what the difference is between the cp-e tuneable and non tuneable? Im thinking of getting it like sometime this week..for the guys who has cp-e how much power approx. did y'all gain?
ones tuneable... and ones not... :lol:
i think the tuneable cpe is more ideal for a supercharged engine...
Postby PXLpainter » Mon Feb 11, 2008 3:23 pm
If you're talking about the Gen 2 V6, then obviously there is no S/C available, but the tunable one has a serial port on the side and comes with a cable and software you can run on your PC to totally fukkup your ride with! :up: :rofl:
If you have no intentions of ever doing this, or have a speed/tune shop do it later, then go with the standard non-tunable version.
Postby anwagbo3000 » Mon Feb 11, 2008 3:49 pm
Agreed
anwagbo3000
Postby white_solara » Tue Feb 12, 2008 6:06 pm
lol it says that u can gain 8.7 wheel hp and 9.1 wheel ft lbs did u guys had that much gain from an intake system?
white_solara
Postby SolaraBlue » Tue Feb 12, 2008 6:20 pm
white_solara wrote:lol it says that u can gain 8.7 wheel hp and 9.1 wheel ft lbs did u guys had that much gain from an intake system?
yes. thats why this system is $500.... you get what you pay for.
Postby unbalancedwood » Tue Feb 12, 2008 6:25 pm
you splice wires into your ecu. Standard aftermarket intakes are 2.75" while the CPE is 3.5". The 'black box' adapts your ECU so it can handle the bigger intake, its worth it!
unbalancedwood
Postby Midias » Tue Feb 12, 2008 7:14 pm
CPE is well worth it I love mine. My only regret is NOT getting tunable I know it is an extra 100 dollars but go for it or you will kick your self when it cost 150 to upgrade later. Also check my sig for some important CPE info.
Yes you will and I think the gen 1 even gained more. Trust me this is a great system.
Postby Down2TheC » Tue Feb 12, 2008 8:36 pm
Just a tiny 1-2 whp is from the intake, the tuning chip does the rest. Leans out the stock air/fuel map = more power and better mpg.
Down2TheC
Postby crispone » Tue Feb 12, 2008 9:11 pm
Hands down, the MOST power I've ever gained with a single mod on anything I've tuned... (bang-for-buck-and-boosted-excluded)
...you will NOT be disappointed...
PS: Jeff... I can't WAIT to phuck it up with the serial cable option... which, of COURSE, I bought UP FRONT! :wink:
Installed at 50k... into 75k now and RIPPING up the streets... 8)
BWAAAAAAHHHHHHHhhh ha ha ha ha ha!
Oh, yeah... don't forget the CRISPMONGO FILTER option...
Heck... it's even better than one of THESE!!!!
heh heh heh...
-crisp :evilbat: :drinking:
Postby white_solara » Thu Feb 14, 2008 10:49 am
hmm...how did u guys tune ur cp-e?
white_solara
Postby Sebas007 » Thu Feb 14, 2008 11:48 am
white_solara wrote:hmm...how did u guys tune ur cp-e?
If you will be stock (no major performance mods) you'll not need the tuneable part. I've the tuneable and I tried some different mapping. Bottom line, it already comes with the optimum mapping.
To tune it, you have to plug the black box to a laptop, then use the CPE software. It is a Excel like sheet with RPM on vertical axis and throttle volts on horizontal axis (the scale is 0 to 5 volts refering to the throttle demand). The numbers you put in those cells are the % of volts change you want to send to the ECU. Starting with the fact the AFR are lean at low demand and rich at high demand, you tune the map this way.
