SolaraGuy.com • View topic - Ever heard of these for 04 and up tail lights?
Postby jdv5900 » Mon Feb 11, 2008 7:19 pm
Hey all,
I am lookin to smoke my tail lights. Love the look, especially on a silver car. I found these while searching around to buy film. Anybody know if there is a difference between this and regualr film?
http://www.autoaccessorystore.com/home_n.asp?dir=detail&id=3000
If you enter the make and model toyota solara 04 and up is available.
although if you go here on the same site there is no solara 04 and up available
http://www.autoaccessorystore.com/home_n.asp?dir=detail&id=1475
If this doesnt work im gonna follow sebas007's lead and get them from instyle graphics cuz i ordered custom eyelids for my silver and they came out great.
cheers
jdv5900
Postby SolaraBlue » Mon Feb 11, 2008 7:22 pm
PM LatinUSMC he might be able to help you out with your tails...
Postby kpxboi0619 » Mon Feb 11, 2008 10:54 pm
I smoked mine with different film.
that film is really thin and it will rip when you are installing it, especially where our tail-light bubbles.
plus that film gives purplish look rather than smoke (black) look.
kpxboi0619
Postby philosophicaljt » Tue Feb 12, 2008 8:14 am
vht makes the best spray.
2004 Solara SLE V6
Search
philosophicaljt
Postby Sebas007 » Tue Feb 12, 2008 9:01 am
philosophicaljt wrote:vht makes the best spray.
Nothing else can beat a good smoking film than a real profesionnal paint job. Spray not doing a nice job when you will close to the car.
I would go with the film all the way !! I use the same as Sean (kpxboi0619). He is the guy that hook me up to this product ! :)
Postby krawzyazn » Tue Feb 12, 2008 11:32 am
your wrong on this lol
Postby philosophicaljt » Tue Feb 12, 2008 11:53 am
Why am I wrong? Out of every spray I have used, the VHT works amazingly well. and its very easy to control.
2004 Solara SLE V6
Search
philosophicaljt
Postby PXLpainter » Tue Feb 12, 2008 12:05 pm
True - ONLY on the Gen 2.5 tails though... prev. Gen 2 tails have that bump making it nearly impossible to get a good fitment of the film on the surface! ;)
Postby rollaevo99 » Tue Feb 12, 2008 1:21 pm
Jeff (PXL) is correct on this, because of this stupid bump I cannot stick the film without having air bubbles.....and I tried so many times :wink: so I would suggest to get 2.5 tails... and have it film. :wink:
Postby philosophicaljt » Fri Feb 15, 2008 5:34 pm
you just need to heat shrink the film to the tailights. Its not that hard. Have a heat gun or a steamer?
2004 Solara SLE V6
Search
philosophicaljt
Postby kingkakyle » Fri Feb 15, 2008 7:15 pm
philosophicaljt wrote:you just need to heat shrink the film to the tailights. Its not that hard. Have a heat gun or a steamer?
its probably harder than it looks....even diong the 2.5 tails seemed to be a bit difficult according to some....i think sebas had his friend help so there were 4 hands istead of two....
unless uve done them to ur gen 2 tails and thought it was easy....then i dont know....but its probably much harder than it looks
Postby PXLpainter » Fri Feb 15, 2008 10:38 pm
Have you done this personally? I'd like to see a successful finished product to support this. So far, I haven't yet.
Postby NightRider » Sat Feb 16, 2008 3:36 am
I thought i'd help. check this guy out he's been doing overlays for a while. He does good work here check it!
http://s2.photobucket.com/albums/y42/BlueBatmobile2005/
2004 Black Solara V6SLE COUPE
Injen polished SRI
TRD FSB 6000K HID's
NightRider
Postby Sebas007 » Sat Feb 16, 2008 5:33 am
Jeff you mean you never see a smoked taillights from him or from anybody on here (Gen 2+ side) ? Because Sean (kpxboi0619) and myself have our tails smoked. He even has Gen 2 but he let the pros at InStyleGraphics
Page 3 - the receipt
http://www.solaraguy.com/viewtopic.php?t=33065
Postby PXLpainter » Sat Feb 16, 2008 9:39 am
I've seen Sean's in person - and they didn't look very good. He had a lot of problems because of the Gen 2 tail "bump" - THAT'S what I'm referring to... applying film to an uneven surface. The material has to go somewhere - it's not like it's vacuum formed or anything, so it's going to pinch, buckle or bubble.
So IF someone has successfully film-tinted their Gen 2 (2004-2006) tails, I'd like to see it, and perhaps they could share their techniques for getting it done properly. ;)
