SolaraGuy.com • View topic - Those of you that have installed their AFC controller Gen1-2
Postby lemmez » Mon Apr 28, 2008 4:11 pm
which method do you guys recommend me using to connect my afc to the ecu.
Crimping method or soldering method?
if crimping:
Which crimping tool should i purchase? i just bought the 7$ one at radio shack and tried it out. It makes horrible crimps. Should i use shrink wrap on top of the butt connectors? What gauge wire is the ecu on a gen 2 18-22?
if soldering:
What soldering kit would you recommend me to buy? what kind of solder?
lemmez
Re: Those of you that have installed their AFC controller Ge
Postby Dawgz » Mon Apr 28, 2008 8:48 pm
lemmez wrote:which method do you guys recommend me using to connect my afc to the ecu.
if crimping:
if soldering:
Dont crimp, u dont want to mess with crimping with a controller like this, if ur gonna do it, solder it.
Get a 30watt solder at minimum and a solder that has 50/50 of rosin/led
Postby lemmez » Mon Apr 28, 2008 9:03 pm
i was just watching a video on how to solder electronic wire and the guy said do not use acid something solder or 50/50.
Why should i use 50/50 solder on the connection between my afc and ecu.
lemmez
Postby kingkakyle » Mon Apr 28, 2008 9:05 pm
because rosin is kind of a "glue" to keep it sticking to the wire
Postby Dawgz » Mon Apr 28, 2008 9:18 pm
Rosin isnt a glue, Rosin is infact a type of acid which will clean the surface u are trying to solder onto. A clean surface is a better surface where the solder can bond to.
http://en.wikipedia.org/wiki/Flux_%28metallurgy%29
Postby PXLpainter » Tue Apr 29, 2008 12:05 am
Actually you're only partially correct... the rosin core works like a flux when it melts on tin and copper. The acid core is for heavier metals like galvanized sheet and plumbing fittings and should be washed off afterwards to reduce corrosion. ;)
Postby Down2TheC » Tue Apr 29, 2008 3:40 am
Those little butane irons work great. Heat up quickly, cool down quickly.
Down2TheC
Postby Midias » Tue Apr 29, 2008 5:18 am
You should attach it like I did for my CPE intake in my sig use a quality thin strand lead based solder not a tin silver (200 degree melting difference) I also like to use electrical flux but that is up to you.
For an iron nothing beats a metcal iron NOTHING but they are very expensive so I like weller second. The WES51 solder station is a very good iron I use them a lot at work.
Here
For a crimping tool get a nice klein tool from sears looks like this
Postby PXLpainter » Tue Apr 29, 2008 7:33 am
Down2TheC wrote:Those little butane irons work great. Heat up quickly, cool down quickly.
I've had my Weller butane for nearly 20 yrs and still works strong... best part is it's cordless! :up:
