SolaraGuy.com • View topic - Weapon R Secret Weapon CEL
Postby rojamay » Mon May 05, 2008 6:07 pm
I keep getting a dadgum CEL after I have installed my Secret Weapon. I have a 2007 Solara coupe w/ 2.4L.
I have checked and re-tightened the worm clamps. I have put black RTV at the MAF just to make sure it was sealing. I am getting the code for the MAF not functioning optimally (something lik 00101) or that the fuel is a little lean.
Anybody had a similar problem with an aftermarket intake? This is probably the 4th car (of mine) that I've put an intake on, and this is the 1st time I have had so much trouble.
rojamay
Postby dvdchris45 » Mon May 05, 2008 6:11 pm
try disconnecting the negative terminal on the battery for 10 minutes then reconnect and start the car. that may solve the problem
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Jakecallun20 » Mon May 05, 2008 6:46 pm
dvdchris45 wrote:try disconnecting the negative terminal on the battery for 10 minutes then reconnect and start the car. that may solve the problem
Yeah that will clear the idiot light, but it may still come back.
Postby kingkakyle » Mon May 05, 2008 6:56 pm
how often do u get the light?
i have an injen and ive gotten the light 2 times in the past...2 years ish....
it says im running lean...so i just d/c the battery and it goes away for a long time....
Postby Aotoyota » Mon May 05, 2008 7:23 pm
disconnecting the battery resets the ECU, it should clear the codes and will learn the new intake and your driving habits.
disconnect for 10-15.. i disconnect then get something to eat. then go driving for about 20mins. drive streets and freeway. after that the ecu should adjust everything so it works tip-top
cheers
Aotoyota
Postby rojamay » Tue May 06, 2008 5:41 am
I'll try it again. I installed it with the battery disconnected, and have disconnected the battery since. However, i have not driven directly after reconnecting the battery. What i have been doing lately is clearing codes with my OBDII reader.
Like I said, I have checked and tightened clamps, RTV'd in a gasket around the mounting point for the MAF in addition. WE'll try it again, though.
rojamay
Postby lemmez » Tue May 06, 2008 2:05 pm
I have the same intake on my 2azfe. I had it installed and never had one cel light from the intake.
lemmez
