SolaraGuy.com • View topic - Squeeze sound on the Rare - need suggestion
Postby alan8888 » Sun May 11, 2008 11:03 pm
I found my car at the rare have squeeze sound while on the bumping road
and is from the Passage side rare suspension.
I have changed the lower spring and has run for 40k miles already. I am not sure is the spring problem or not.
One if my friend told me is possible is the Coil getting Old.
Another frd told me is because of the upper mount.
If is the Coil problem should I change both rare coil to the KYB Coil ? it seems pretty reasonable price.
Will the spring getting to get soft because i already used 40k miles. should I changed that as well ?
alan8888
Postby CASTRO » Sun May 11, 2008 11:50 pm
at the "rare" huh? :rofl:
CASTRO
Postby boaclub923 » Mon May 12, 2008 12:45 am
go get the diagnoses from dealer...
it could be many reasons..
rear sway bar's screw lose (that's what happened to mine)
or broken shocks
it could be anything..
if the screw is lose on sway bar, usually they will cancel the charge on diagonosis, and free tighten the sway bar..
if the trouble is other than sway bar,
it will be too price for u to guessing around and change the parts around..
so.. get diagnosis
boaclub923
Postby SolaraBlue » Mon May 12, 2008 8:38 am
CASTRO wrote:at the "rare" huh? :rofl:
X2
did Borat buy a solara and become a member? :o
Postby alan8888 » Mon May 12, 2008 10:16 pm
i am just thinking to bring to some local car shop
alan8888
