SolaraGuy.com • View topic - broken bolt from rsb
Postby GzNutz » Wed May 14, 2008 12:45 am
So...today I noticed a nice clicking from the rear when going over bumps. Got home and peeked under the car. The upper bolt head on the rsb mounting bracket was missing. Upon closer inspection I saw the bolt had snapped in half. Has anyone had this happen and was this more than likely a case of over-tightening the bolt?
Postby Sebas007 » Wed May 14, 2008 4:47 am
Yep...I would say the torque spec wasn't respected there my friend. It sucks. I hope you will have not too much difficulties to un-bolt the reamining bolt half.
Postby Down2TheC » Wed May 14, 2008 6:39 am
Isn't that the second sheared RSB bolt for SG in a week? Watch out guys... these things come in threes.
:evil:
Down2TheC
Postby Midias » Wed May 14, 2008 7:05 am
Postby [SMAN] » Wed May 14, 2008 7:40 am
you guys are getting me worried, i'm installing mine this evening...
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Midias » Wed May 14, 2008 7:55 am
[SMAN] wrote:you guys are getting me worried, i'm installing mine this evening...
Spray pb blaster on everything right now
Postby [SMAN] » Wed May 14, 2008 8:05 am
pb plaster?
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby Midias » Wed May 14, 2008 9:17 am
My bad PB blaster look for it at any auto parts store.
Postby [SMAN] » Wed May 14, 2008 9:20 am
Ohh it's just a penetrating oil. I have some of that i think.
2004 Solara V6 SE
1996 Camry I4
[SMAN]
Postby SolaraBlue » Wed May 14, 2008 9:37 am
what kind of lube do you use for the bushings? mine are squeaking a bit...
Postby Midias » Wed May 14, 2008 10:33 am
SolaraBlue wrote:what kind of lube do you use for the bushings? mine are squeaking a bit...
Teflon paste worked for 1.5 yrs no squeaks through NYS salt and snow from 5-100 degrees F.
Get it in the plumbing section of home depot.
Postby dvdchris45 » Wed May 14, 2008 12:39 pm
I picked up a small can of Mobil 1 synthetic grease from Autozone that'll probably last longer than the car
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Midias » Wed May 14, 2008 12:57 pm
I tried that worked well til about 1/4 way through winter then squeak came back with a vengeance.
Postby Down2TheC » Wed May 14, 2008 5:14 pm
My mobile1 is still squeak free. I'm guessing 15k on it.
Down2TheC
