SolaraGuy.com • View topic - se strut quest.
se strut quest.
se strut quest.
Postby LostSoul » Tue May 27, 2008 11:10 pm
so if i got the se struts & add the trd rsb would it be similar if i had the se sports by itself or still going to be bouncy?how harsh is the rides performance?
should i just get the se sport struts?
LostSoul
Postby kingkakyle » Wed May 28, 2008 12:01 am
newer ones are red
older ones are black
same springs though
Re: trd springs help!!!
Postby LostSoul » Mon Jun 16, 2008 9:02 pm
LostSoul wrote:does anyone know why theres two diffrent colors for red & black?
where are the bolts to remove the rear springs?in the trunk or behind the rear seats ? i havent tried looking just a qwick question
LostSoul
Postby ThatVietGuy » Mon Jun 16, 2008 9:12 pm
Behind the rear seats. Or more precisely, buried beneath all the crap in the back.
ThatVietGuy
Postby LostSoul » Mon Jun 16, 2008 9:20 pm
ThatVietGuy wrote:Behind the rear seats. Or more precisely, buried beneath all the crap in the back.
thanx t.v.g.
LostSoul
Re: se strut quest.
Postby LostSoul » Sat Jul 05, 2008 12:42 pm
LostSoul wrote:so if i got the se struts & add the trd rsb would it be similar if i had the se sports by itself or still going to be bouncy?how harsh is the rides performance?
LostSoul
Postby Biggi_e » Sat Jul 05, 2008 12:45 pm
i have a sle with se sport struts and eibach lowering springs. i had a trd rsb but i sold it. the rsb makes a huge difference in the body roll and will help with suspension performance. the ride quality will always drop if you lower your car. its somewhat bouncy to me but i dont mind as long as you avoid big dips on the streets and all.
Postby LostSoul » Sat Jul 05, 2008 12:49 pm
Biggi_e wrote:i have a sle with se sport struts and eibach lowering springs. i had a trd rsb but i sold it. the rsb makes a huge difference in the body roll and will help with suspension performance. the ride quality will always drop if you lower your car. its somewhat bouncy to me but i dont mind as long as you avoid big dips on the streets and all.
how much do sprt struts go for?
LostSoul
Postby Aotoyota » Sat Jul 05, 2008 2:06 pm
I beg to differ... depends on the setup. I just put in my suspension with the KYB-GR-2:KYB strut mounts: TRD springs, and the car rides smoooth now. plus it is quicker and more nimble than with the RSB...
I recommend the KYBs especially if you aren't going to drop the car more than 1.5inches! and they were a lot cheaper than the toy sport ones.
and i have an SE sport...
Aotoyota
Postby CosmicGrooves » Sat Jul 12, 2008 6:01 pm
I would imagine the sway bar with SE struts would leave the UP-and-DOWN motion of the suspension the same, but stiffen the SIDE-to-SIDE feeling motion.
The SE Sport struts would stiffen the UP-and-DOWN motion.
I have the SE Sport but no sway bars... I can see how they would be beneficial from a performance perspective. It is actually more comfortable at 100 mph than at 60 mph. The Sport struts are good for that because it's just long straight roads and the car is mostly only experiencing up and down motion.
The sway bars would help going around corners.
Each of them though decrease the softer, luxury-like ride the SLE has over the Sport.
CosmicGrooves
