SolaraGuy.com • View topic - SRI installed! help
SRI installed! help
SRI installed! help
Postby shobo » Wed Jun 04, 2008 7:08 pm
I need help!!!!!I just installed my Injen SRI on my 2004 solara I4 and now my car battery keeps dying; even while im driving. I went to Autozone and the guy tested the battery and he said its still good.
This is what happened, after I finished with the installation....I connected the negative battery...start the car..wouldn't start...start it again..wouldn't start...3rd try and the car starts...feels sluggish while i accelerate and then dies while im on the road....also my car window won't go up or down automatically...WTF!!! HELP!!!! This is my only transportation for school and finals is coming up...AHHHHH
P.S: I followed through all the steps and the intake sits very tight and strong....so iono wats up.
shobo
Postby BadAngel » Wed Jun 04, 2008 7:24 pm
I just installed it on my 04 SLE v6 as well... I didn't run into any problems like this... i cant Imagen how this could possibly mess with the battery. Unless you somehow made a connection in the wire that your supposed to disconnect and tuck away. (the one that connects to that second valve that is eliminated on the left side of the stock intake) I am not sure if this applys to the I4...
As for your window problem, thats just because the battery was disconnected. To reset the auto window you need to open the window shut the car off leaving the key in the ignition. Then close the door, open it and start the car and it should work automatically again.
BadAngel
Postby kingkakyle » Wed Jun 04, 2008 7:58 pm
disconnect the battery again make sure all the connections are correct
after u reconnect the battery and restart the car let it idle for 5-10 minutes
this might help
also the auto windown
press and hold all the way down until the window is down
then pull up and hold up until its all the way up....hold for a few seconds... then should be full auto again
Postby BadAngel » Wed Jun 04, 2008 9:02 pm
kingkakyle wrote: also the auto windown
thats for the sunroof only isn't it? .... i just reset my window and i hadda put the window down turn the car off close the door open it again and then start the car for it to be automatic
BadAngel
Postby dvdchris45 » Wed Jun 04, 2008 9:23 pm
kingkaykle's right...just hold it for a few seconds. i dunno what that opening and closing door nonsense is about lol
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby kingkakyle » Wed Jun 04, 2008 9:49 pm
trust me it works....ive done it many times....
for sunroof....
u just press and hold tilt and then ull hear it move a 2nd time thats when u know the sunroof is set
Postby BadAngel » Wed Jun 04, 2008 10:23 pm
kingkakyle wrote:trust me it works....ive done it many times....
for sunroof....
shobo wrote:also my car window won't go up or down automatically...WTF!!! HELP!!!! This is my only transportation for school and finals is coming up...AHHHHH
dvdchris45 wrote:kingkaykle's right...just hold it for a few seconds. i dunno what that opening and closing door nonsense is about lol
Yeah that works for the sunroof... but he needs help with the window not the sunroof...
heres where i found out how to do it.... so theres no "nonsense" ... i did it yesterday after i installed my ingen SRI
http://www.solaraguy.com/viewtopic.php? ... highlight=
boaclub923 wrote:Nah~ it’s true..
I know it sounds odd that 1-touch window/sunroof has to reset once battery disconnect.
I know it’s not only happening to solara.
most cars which has 1-touch function required reset if battery disconnect. (i know every Honda has to reset also.)
but then, i never heard relearn process required to take door panel off...
Reset process is pretty easy...
1.turn the car power on (leave driver side door open)
2.roll the window all the way down (or open sun-roof fully open)
3.turn off the power then close the door properly
4.turn the power on again
5.close the window all the way up (or fully close sun-roof)
6.turn off the power
1 touch system should work now. Otherwise, contact dealer~
Note: this works for the WINDOW only.... for the sunroof kingkakyle is correct...
BadAngel
Postby Down2TheC » Wed Jun 04, 2008 10:30 pm
Wire brush the terminals on the battery and hook it up again. Or if you have some contact spray, that stuff rox.
If that doesn't fix things, make sure you didn't mess with the alternator.
Down2TheC
Postby [SMAN] » Wed Jun 04, 2008 10:37 pm
Yeah this really sounds like your not making a good connection. I had this with my camry where it wasn't tight, and was vibrating loose on the highway.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby shobo » Wed Jun 04, 2008 10:45 pm
yo yo yo...thx for the advice on the window...I will try it. As for the battery, its working now. I think my battery was drained and I should of let it charged for awhile before taking off. I was too excited to try out the new intake...wat can i say?....Well, as for the intake...im loving it...love the growling sound....especially at night when I'm driving down the street....I feel very sexual every time the engine growls....As performance wise.....I had the K&N filter before and its nothing compared to this. The injen intake is more responsive and definately my 0-60 take off has improved from the low end to high end....but thats just my 2 cents...All solara owners should definately look into this as your upgrade for performance.
Model: 2004 solara I4
Current Health status: 128,000 miles
Operation: New Injen SRI
Any prior problems: none (knock on wood)
:P
shobo
Postby dvdchris45 » Thu Jun 05, 2008 12:59 am
shobo wrote:yo yo yo...thx for the advice on the window...I will try it. As for the battery, its working now. I think my battery was drained and I should of let it charged for awhile before taking off. I was too excited to try out the new intake...wat can i say?....Well, as for the intake...im loving it...love the growling sound....especially at night when I'm driving down the street....I feel very sexual every time the engine growls....As performance wise.....I had the K&N filter before and its nothing compared to this. The injen intake is more responsive and definately my 0-60 take off has improved from the low end to high end....but thats just my 2 cents...All solara owners should definately look into this as your upgrade for performance.
:P
that's a helluva a butt dyno you're experiencing lol...check out the cp-e intake for REAL performance gains and additionally check your car to see if it's VIN number falls under the throttle lag/response problem the early 2004 models had...that might be a little extra something to give your 4 banger a boost!
dvdchris45
