SolaraGuy.com • View topic - RSB Bolt Placement
RSB Bolt Placement
RSB Bolt Placement
Postby BadAngel » Mon Jun 16, 2008 1:49 pm
Alright, i know i remember reading this somewhere but for the life of me i cant find the post that talks about it... I am installing my RSB tomorrow and i wanted to know which of the three bolt settings i should be using. I know i remember someone saying that the holes on the very end will yield little to no results, and that the innermost holes will tighten up the suspension and increase handling considerably. Which holes do you guys who have allredy installed your RSB's recommend?
BadAngel
Postby ThatVietGuy » Mon Jun 16, 2008 1:52 pm
I'm pretty sure 99% of the people here with the TRD RSB have it on the stiffest setting and that is what they'll recommend.
ThatVietGuy
Postby BadAngel » Mon Jun 16, 2008 2:08 pm
Yeah thats what i thought... and thats what i know tacti did cuz i looked at a pic of his RSB and thats where the bolts are.... thanks!
BadAngel
Postby PXLpainter » Mon Jun 16, 2008 2:39 pm
^^ True dat - otherwise it's not really any different than OEM!!
Postby Down2TheC » Mon Jun 16, 2008 9:17 pm
Gotta disagree. I started with middle setting and it's still a huge difference. But then I got used to it and wanted more stability. So yeah... jump to the end.
Down2TheC
Postby [SMAN] » Mon Jun 16, 2008 9:25 pm
See and i started with the stiffest setting. On top of trd springs and 19 rims with rubber band tires. And while the stiffness was great, the potholes and sharp driveway entrances proced to much for me. So i had to go to the middle setting, and i must say it was a night and day differnece. Now the car doesn't bang when i hit potholes and it feels so much smoother. Yes i did give up some of the stiffness so the car does pitch a bit, but not realy as much as the factory setup does.
2004 Solara V6 SE
2005 4Runner V6 Sport
1996 Camry I4
[SMAN]
Postby Sebas007 » Tue Jun 17, 2008 3:29 am
I'm also at the middle setup. I wonder how it feels like at the stiffest setup.
Postby PXLpainter » Tue Jun 17, 2008 10:50 am
You guys are pussies with the middle hole setup! :roll:
Postby kingkakyle » Tue Jun 17, 2008 1:39 pm
lol i felt more of a comfort difference with the trd springs than the rsb
go for the INNER setting!!!! :D
Postby dvdchris45 » Tue Jun 17, 2008 1:58 pm
PXLpainter wrote:You guys are pussies with the middle hole setup! :roll:
i second that! i started with the middle and switched it to the innermost setting a few days later. the diff is night and day!
1st hole FTMFW!
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby BadAngel » Tue Jun 17, 2008 2:02 pm
lol allright I put it in the first hole and i really feel the handeling difference... i took i to a big parking lot and just turned the wheel all the way and gassed it lol the back tires started to give way before the car started to lean hahahaha. While on a highway i turned the wheel back and fourth a bit and you could feel the front rocking while the back was like yeah w/e i'm gonna not move at all xD... Next step is lowering springs >.> i'll be doing that mid summer and i'm sure i'll be asking yall what shocks to get and whatnot lol.... Thanks for the input it was much appreciated!
BadAngel
Postby PXLpainter » Tue Jun 17, 2008 3:17 pm
^^ Next step is to get the FSTB (Front Strut Tower Brace) and the front sway will go away too! ;) :up:
Postby GzNutz » Tue Jun 17, 2008 3:32 pm
^^^ 2x
Postby anwagbo3000 » Tue Jun 17, 2008 4:38 pm
^ lol, i put mine on the inner most setting as well and i love it
anwagbo3000
Postby Sparky5e » Sun Jun 22, 2008 12:07 pm
I have the FSTB and RSB.
I may not be smarter thena 5th grader, but I'm not a pussy LOL
Mine is in the middle position. Has been since it was installed. I LIKE the smooth ride but also like the fact it handles better then stock. When I test drove a sport model it shock me pretty good. I've had sport suspension on other cars and while they handle great, they suck for cruising comfort.
With the FSB and middle position the car is balanced pretty good. Who knows I may be happier in the front hole, but enjoy the smoother ride with improved handling.
07 SLE Convertable
Blue Streak Metallic
Sparky5e
