SolaraGuy.com • View topic - Trying to add air/fuel gauge to Solara......
Postby mnmattie » Thu Jun 19, 2008 9:00 pm
Hey guys,
I'm trying to add an Air/Fuel gauge to a 04 Solara and I've come to find out its a factory wideband in there. Has anyone ever successfully installed one?
Can I run a AEM/Autometer wideband and splice into the factory wires?
Much help needed!!!!!!!!
-Mattie
mnmattie
Postby woa_its_j3ff » Thu Jun 19, 2008 9:39 pm
a WHAT factory wideband??
Postby mnmattie » Thu Jun 19, 2008 10:09 pm
well the replacement calls for a wideband O2 sensor.......
mnmattie
Postby Camry Racing » Thu Jun 19, 2008 11:57 pm
you can run a Wideban but usually you use a new sensor for the gauge the other gauge that you can use your stock o2 sensor is the normal air fuel gauge but your car will turn on the cell if you conect a gauge in a stock 02 sensor
Camry Racing
Postby mnmattie » Fri Jun 20, 2008 12:14 am
so are all solara's narrowband then??? just to clarify?
mnmattie
