SolaraGuy.com • View topic - Pulling to left, while braking
Postby harp00n » Sat Aug 23, 2008 6:26 am
My car was in accident in the USA, it was hit to the right front side, it ran only 800 miles then. Mechanics changed the right coil spring and some other parts from the right side. Then it came to the Ukraine to my friend and here other mechanics changed only the left coil spring as they thought it would be ok (stupid guys, never heard of changing ONE coil spring). And then I bought this car from a friend and started to love, as it's very good.
The problem is that while I'm braking the car is pulling to the left. And it starts to pull harder when the braking is almost over, at the low speed. Normally, if I don't brake, the car is deadly straight (if the road is good), it doesn't pull or drift anywhere.
Alignment is good, brakes seems to be ok too (but the right brake pad dies faster than the left one).
I think, maybe I have a little bit different front coil springs (maybe even with one factory number, but different manufacturer time) and when I brake the weight of the car goes to the front and if the left spring is softer it pulls me to the left.
The idea is to swap springs to see, if it will pull me to the right and change them if it will.
The next question, can I use the coil springs from the Euro Camry 2.4 '05 as they are available here. Or maybe I should try them from EuroCamry 3.0? What do you think?
harp00n
Re: Pulling to left, while braking
Postby gnegroni » Sat Aug 23, 2008 8:59 am
harp00n wrote:My car was in accident in the USA, it was hit to the right front side, it ran only 800 miles then. Mechanics changed the right coil spring and some other parts from the right side. Then it came to the Ukraine to my friend and here other mechanics changed only the left coil spring as they thought it would be ok (stupid guys, never heard of changing ONE coil spring). And then I bought this car from a friend and started to love, as it's very good.
You should check into the Toyota TSB for pulling to the left (for acceleration though). The repair procedures says something about rotating the spring... some Solaraguy members have dealt successfully with the problem (with mechanic help).
Still, you mention the car is pulling while braking. Was the car aligned after the repairs? Maybe there is a problem with the braking system on either side (less braking on the side where it doesn't pull and/or more braking power on the side it pulls to?)?
gnegroni
Postby System_Crash » Sat Aug 23, 2008 2:13 pm
Somehow I think this is a braking issue like a caliper sticking or glazed pad or rotor/ To start with I would machine the rotors and put a new set of ceramic pads and while doing so would check the caliper seals/slides if everything is ok there I would then get into brake lines (see if one is twisted around from a brake job) or the proportioning valve/ OR the ABS module itself (probly not or the CEL would be on) anyway thats how it would go at our stealership OR I could give you the benifit of the doubt and assume it IS the springs; What kind of miles on the car when the second one was installed? did it ride OK for awhile? did it get progressively worse?
Pearl White 2004 Solara V6 90,000 miles
System_Crash
