SolaraGuy.com • View topic - Milwaukee Shop
Milwaukee Shop
Milwaukee Shop
Postby GzNutz » Sat Aug 23, 2008 1:19 pm
Can anyone point me in the direction of a good shop in Milwaukee or w/in an hour of the city that would be reasonable to get some springs installed?
I attempted to remove the driver side front only to find the wonderful effects of salt on bolts...ie. rounded heads. Rather than waste more time creating a bigger mess I would like to just let a shop handle it. Unfortunately I've made several calls and the lowest I've gotten quoted for is 5-6hrs = $500 with me supplying the springs. I know that price is bullsh!t and am sure there is a much cheaper alternative other than diy.
So if anyone has an alternative or a hook up, I would be very grateful!
Thanks
Postby System_Crash » Sat Aug 23, 2008 2:18 pm
May I suggest the Craftsman 10 pc. Impact Grade Bolt-Out™ Damaged Bolt/Nut Remover
Sears item# 00952165000 Mfr. model# 52165
It's more satisfying DIY dont forget to pickup an oncar spring compressor or borrow one from auto zone
Pearl White 2004 Solara V6 90,000 miles
System_Crash
Postby GzNutz » Sat Aug 23, 2008 2:54 pm
Thanks for that tip. I had already picked up the compressor, but I'll have to go check out that bolt-out tomorrow.
Postby behrozec34 » Sun Aug 24, 2008 12:22 pm
maybe try Reina International on capitol drive in Brookfield
behrozec34
Postby Sparky5e » Sun Aug 24, 2008 10:09 pm
There's a product called PB Blaster. It is by far the best pentrating solution on the market. I can't tell you how many times we have had rusted fasteners and afer 24 hrs they come apart with hand tools. Don't get me wrong, it isn't a fix all for corrosion but is still some pretty good stuff.
07 SLE Convertable
Blue Streak Metallic
Sparky5e
Postby System_Crash » Mon Aug 25, 2008 2:26 pm
I agree; Zep 45 is also a good one
System_Crash
