SolaraGuy.com • View topic - 18' tire quest
18' tire quest
18' tire quest
Postby LostSoul » Mon Sep 08, 2008 6:37 am
sorry for noob quest. i know there's tire calculators and everything but need a quick answer?
would i be cool on 235/45/r18 on 45 offset??(dropped on trd's)
rim size is 18/7.5
LostSoul
Postby Biggi_e » Mon Sep 08, 2008 6:41 am
not sure about the offset but the tire size your fine on
Postby Sebas007 » Mon Sep 08, 2008 6:48 am
I would buy +5mm spacer to bring your offset to +40mm. 5mm are cheap compare to bigger spacers and it will make your car look stronger. And be sure to be dropped because the 18's will look very small.
Postby PXLpainter » Mon Sep 08, 2008 10:36 am
You'll be fine with that size and offset. At least you won't have rubbing issues.
