SolaraGuy.com • View topic - mike t grille
mike t grille
mike t grille
Postby someazn » Sat Oct 11, 2008 12:38 pm
How do you guys secure the bottom of the top grille? I used the default screws that came off the OEM grille to secure the top, but I don't want to use zip ties to secure the bottom because it'll show. Any ideas? Thanks.
someazn
Postby LostSoul » Sun Oct 12, 2008 2:55 pm
But if your grill is black and you use black zippies is that bad ?
LostSoul
Postby kingkakyle » Sun Oct 12, 2008 3:11 pm
yes it is....if u see a car with zipties holding it up looks kind of ghetto
i only use it for my lower grille cuz i use it behind the license plate and u have to bend down to look at it
Postby someazn » Sun Oct 12, 2008 4:05 pm
yea its pretty bad with the zip ties
someazn
Postby LostSoul » Sun Oct 12, 2008 4:07 pm
kingkakyle wrote:^^^
so if you have zip ties behind your licence plate what are you holding it with on the sides?
LostSoul
Postby Ruski » Sun Oct 12, 2008 4:14 pm
Try hot glue or some sort of adhesive
Postby kingkakyle » Sun Oct 12, 2008 7:04 pm
well since mine is on the lower part i have zip ties across the top holding to the "teeth" so unless u bend down....like knees on the ground u cant see them since its all black down there and i put the "knot" on the back side
Postby yogi » Wed Oct 22, 2008 5:03 pm
on/off topic...do you guys know if mike t is back in business?
I visited his website and he said that everything is on hold now...
"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones." by Albert Einstein
yogi
